2016 LX TPMS programming
Does anyone know if 2016 LX can remember 2 sets of tires or just one as any other Toyota?
My dealer said since 2013, it can only take one set of five tires. Gone is the way you could code summer/winter sets. Then again, I find the online communities are often more knowledgeable about tech capabilities of the cars than the dealers.
I've had a yellow light on the ip since I installed Tundra wheels with Blizzaks but definitely a first -world problem.
Steve
If you can live with a false tire pressure warning when you have your off road tires on, you can play in the dirt without issues. Or, you have to program the TPMS with every switch.
You can supposedly program with Techstream, but you have to do it with every swap. Gone is the feature of being able to program 10 tires (5 summer, 5 winter or offload in your case). You keep programming 5 every time you swap.
Matt,
Understand, sure beat going to the dealer or tire shop every time doing the tire swap. There are two versions of techstream, one is for window XP cheap ~$20 to $30, but need to have a laptop that still has window XP. The newer one use window 7, cost about $700, but I don't know it will support window 10 or not.
Matt,
http://www.ebay.com/itm/221720133329?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Thread on mud related to TIS overall...installation stuff starts around the middle of page 2. Posted by Luke27617 who I think is also a member here...
http://forum.ih8mud.com/threads/tis-...-lc200.910126/
This little guy is, so far, well thought of on Mud. I've got the disk and OBDII-USB cable. $60 and about a week from China. It supposedly runs well on Win 8 and previous versions back to XP. I've been too busy to install and play with it, but I will report back when I bet it cooking...
ebay techstream disk and cable
I don't have window 8, my laptop is window 10. I don't think the Chinese techstream works with window 10... I need to find an old laptop with window XP
Yes please check to see if it work with window 8. My brother and cousin both got one each, the cousin one can't work with his XP laptop, only work with my brother XP laptop, and my brother techstream can't work on his own laptop... Crazy
There's a reason I linked to the cable and software on eBay...click, and read the software specs. You'll find what you need.
