LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Has anybody put Land Cruiser wheels on your LX570?
Old 11-07-15, 08:33 AM
Superbeast
Superbeast's Avatar
Default Has anybody put Land Cruiser wheels on your LX570?
So that you can put on a taller sidewall all terrain tire, like a BFG TKO?
I love my new (to me) 2011 LX, but one of my few complaints are the relatively low profile tires due to the 20" wheels.
I'd love to hear some thoughts.
Thanks!
Old 11-08-15, 08:20 AM
Superbeast
Superbeast's Avatar
I guess the other option would be to go up a size in sidewall height, from 285 50 to 285 55.
BFG makes all terrains in that size. Anybody done that without any negative effects?
Thanks again in advance for any info.
Old 11-09-15, 05:48 PM
rmawyer
rmawyer's Avatar
Since you're not getting much feedback, guess I might as well point you here...tons of info.
http://forum.ih8mud.com/forums/200-series-cruisers.136/
http://forum.ih8mud.com/threads/200-...tabase.818686/
Going to smaller Land Cruiser 18" wheel is best answer. Bolt patter should be the same, but lots of other options with Tundra wheels etc. And yes, after moving from 16" wheels on my 80 series, then 18" on my 100 Series, the 20" on my 200 Series make me even more nervous. Can't imagine 21" on the new one. ;-)
>>> Just stumbled across this thread: http://forum.ih8mud.com/threads/can-.../#post-9447602
Old 11-10-15, 06:52 AM
TomMartin
TomMartin's Avatar
'04 Land Cruiser with 18". Went up +1" in diameter of tire primarily to fill up the wheel well Worked great. Tirerack can show you the size impact. On second set now. TomMartin
Old 11-10-15, 07:35 AM
DAMBIGlsu
DAMBIGlsu's Avatar
I actually battled with this problem because I wanted to go with a tire with more bite in it than the typical continental or Michelin. I ended up going with the continentals because going up to BFG's or Toyo's would have run me well over $1000. Another less popular option is you can size down to a 275/60R20. The diameter will be large on the 275 due to the higher side wall BUT you lose almost .5 inch of width. Sizing down will save you some $$$. I like the 20's so I never considered swapping out the wheels but I know there are plenty of options out there for cheap if you look around.
Old 11-10-15, 07:23 PM
Superbeast
Superbeast's Avatar
Thanks so much for the replies everybody.
The tires that came on it are fairly new, so I'm not in a huge hurry. I just want to have a plan when it comes time.
So changing the overall diameter, whichever way you do it, wont mess up any of the electronic gadgetry like speed sensors, ABS, ride height adjustments, or anything?
Tom Martin, you didn't experience any negatives did you?
I'm coming from a 1999 4x4 4Runner, so this thing is like trying to pilot an alien spacecraft after getting out of a Model T!
LOL
Thanks again!
Old 11-12-15, 01:40 PM
twinturbov
twinturbov's Avatar
We went with the 20" Tundra wheels and 285/50/20 Blizzaks for winter wheel/tire setup. Because of the much deeper tread on the snow tires the truck drove sooo much smoother than the reasonably new Michelin Lattitudes on the Lexus 20" wheel.
Knowing the tread depth of BKG TKOs, I bet you'd feel more confidence because they have a stronger sidewall and those deeper treads. Basically stick with the 285/50 setup but beef up the truck/wheels at the same time.
Here's what the setup looks like. Vehicle is in low position in this photo.
Old 11-28-15, 09:18 AM
Headless
Headless's Avatar
Not really LC wheels, but the 17 TRD Rock Warrior wheels from a tundra. This is a popular option on the LC.
Went with 285/70R17 BFG AT KO2. I have been very happy with this combo.
Old 11-28-15, 11:04 AM
DarkStar12
DarkStar12's Avatar
Nice TRD wheels. How do the BFG ride compared to stock 20" Bridgestone/Michelin? Is the tire diameter the same between the two wheel types?
Old 11-28-15, 04:22 PM
Headless
Headless's Avatar
I had the Dunlop tires and hated them. The BFG are a bit larger (32.8 vs 31.2).
The ride and noise is very similar to the stock size tire. Turn in and over all handling is a little less sharp, but I think that is to be expected.
I would run this setup again in a heartbeat. Very happy with both the looks and handling/ride comfort.
Old 11-29-15, 08:27 PM
Headless
Headless's Avatar
I got lost looking for the mall!
Old 11-30-15, 08:08 AM
T4Fun
T4Fun's Avatar
how about these 22inch oem toyota rims.
very very nice.
http://www.ebay.com/itm/22-Toyota-Tu...BWL~R3&vxp=mtr
same bolt pattern, but not sure about offsets of LX, sequoia, LC and tundra, but likely all should be same
Old 11-30-15, 02:47 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
factory "style" means they are not oem. and that price is a given too
Old 12-02-15, 12:05 AM
T4Fun
T4Fun's Avatar
yes youre right i overlooked that.
Old 12-08-15, 02:57 PM
JDJackson
JDJackson's Avatar
I'm looking to do the same thing, for the same reason. I looked up and the 2010 LX actually had an 18" option for rims. I tried to see if I could get a set, but at $600 each, that WAS NOT GOING TO HAPPEN! So, I am now looking at Tundra take offs from my local dealer, since I can get them at roughly $100 ea. With that said, the OEM 18" rims had the same dimensions as the LC, as the Tundra and Sequoia. So, you can take the LC rims and use them on the LX without issue. I would not mind having a set of the LC rims, but cannot find any so like I said, I am looking at the Tundra rims.
I do like the looks of the Tundra TRDs, but the cost is higher than I would like to spend, plus EVERYONE on the MUD is using them. I am thinking of powder coating the Tundra take offs to a darker grey before putting them on my 2010 LX.
Quick Reply: Has anybody put Land Cruiser wheels on your LX570?
