Tips on Driving on sand dunes/Beaches - Club Lexus Forums
Thread Tools Search this Thread
Old 05-12-14, 07:37 PM   #1
UZ214
UZ214's Avatar
Default Tips on Driving on sand dunes/Beaches
I took the LX on the beach last weekend, took it right next to shore- at first i didnt lower the pressure on tires i thought maybe i would be ok- everything auto and it did well. But when i came to the soft parts of the sand i felt it had some trouble so i stopped right away adjusted the pressure - i was at 19 Psi and then drove.
The kids had a blast and it was fun- i have driven in snow storms but it was my first time on sand and to be honest it was a fun experience.
All the cars around be were lifted Ford F150s or Rams pick up trucks with huge tires and it was cool to a LX between them.
On the way out i almost got stuck to the same place where i parked, i felt the VSC kicked in and just stopped the car. Then i put her in manual gears and kept it at a low gear 3rd and it did fine.
Now question to the more experienced guys, do i need to turn the VSC off? do i lock the differential?
or just go to L4, from H4? -
thanks for the input guys
UZ214 is offline   Reply With Quote
Old 08-05-14, 10:12 PM   #2
See5
Hi, you should indeed look the differential once you enter sand. Switch to L4 when you feel you are about to get stuck.
Your car also has crawl mode where it can get her self out when its stuck. I would suggest reading the owner manual to benefit your self more about the systems in the car.
regards
See5 is offline   Reply With Quote
Old 10-13-14, 04:59 PM   #3
Surfy
Yep, read your manual - otherwise you don't will be able to use your car well.
The LX570 and the Land Cruiser 200 are very capable in the dunes..
The guys love it in the UAE:
http://www.4x4tripping.com/2014/05/v...andspiele.html
I love it during our Transafrica
http://transafrica2012.blogspot.com
Have fun
Surfy
Surfy is offline   Reply With Quote
Old 11-07-14, 02:16 PM   #4
UZ214
UZ214's Avatar
nice pics!!!
they all seems to have smaller tires, maybe 18s? ours have 20 which i dont know if its a good thing.
Old 12-12-14, 05:54 AM   #5
Surfy
Quote:
Originally Posted by UZ214 View Post
nice pics!!!
I don`t travel with stock setup
I did change my tyres to 285 / 70 / R17
Surfy
Tips on Driving on sand dunes/Beaches-landcruiser-200-j20-worldtrip-transafrika.jpg
Old 12-12-14, 09:07 AM   #6
Max707
Max707's Avatar
I would think that the wider 20's would work better then the narrow 17's in the sand? Float on top versus digging in.
Max707 is offline   Reply With Quote
Old 08-17-15, 02:11 PM   #7
prwdmd
prwdmd's Avatar
I'd have to disagree with you on this... I have had a lot of experience driving Land Rovers in all kinds of sand conditions. Of course you lower air pressure if possible. But driving in sand I would keep it in 4H most of the time and keep your foot on the throttle. Low gear will only limit your speed and you don't need the extra low end power in sand, you need speed. Locking the center differential will negatively affect your steering. I'd only lock it if the vehicle felt like it was getting stuck. Definitely turn off all the VSC and electronic aids.
regards
prwdmd is offline   Reply With Quote
Old 09-08-15, 12:27 PM   #8
UZ214
UZ214's Avatar
this is the way the car should cover from factory .I mean we didn't buy a RX for a reason. thanks for sharing the pics. looks great
Surfy
Old 10-15-15, 08:19 PM   #9
M1911
For the past 13 years, I've spent two weeks each summer on the beach in my '03 4Runner. I always lower my tire pressure to 15 psi and lock the center diff. I usually use 4 lo, not because I need the torque multiplication. Using 4 lo keeps my speed down, which keeps me from bouncing around so hard that I bottom out the suspension. But 4 hi works fine as well.
In those 13 years, I've never gotten stuck.
M1911 is offline   Reply With Quote
Old 10-16-15, 08:59 AM   #10
hankinid
hankinid's Avatar
I'd definitely suggest 17" or 18" rims/tires for off-road, including sand. FAR more capable tires available than oem mall-cruiser 20's. I tend to lower pressure to around 20 psi and keep the speed up to avoid floundering and sinking. I'm not sure the crawl mode would help in sand as I haven't needed to use it.
hth
Steve
hankinid is offline   Reply With Quote
Old 10-16-15, 09:49 AM   #11
M1911
Quote:
Agreed. The point of lowering your tire pressure is that the tire flattens out, increasing the contact patch. It is like the difference between walking on the beach in saddles versus heels. The 17 and 18 inch tires have taller, softer sidewalks that let the tire flatten out more than the short, stiff sidewalks on 20 inch wheels.
Old 10-16-15, 11:21 AM   #12
hankinid
hankinid's Avatar
Quote:
I haven't walked on the beach in heels since I moved from the SF area 25 years ago.
I'd also note that another advantage of smaller diameter rims is that a taller sidewall gives you more flex off road, and a consequently far more comfortable ride. Not to mention far less chance of denting a rim if you try something stupid.
I replaced the oem-size tires on my '01 LC with LT285-70x16R Toyo A/T's right after getting the truck. Yeah, it doesn't cut corners on-road like the oem tires, but if I wanted a canyon-carver I'd not have bought an LX in the first place.
Steve
Old 10-16-15, 12:06 PM   #13
M1911
So, these days you only wear the heels on nights out in the city?
Old 10-17-15, 06:19 AM   #14
hankinid
hankinid's Avatar
Nope.
These days I wear heels a lot...but they're all made by Tony Lama, Justin, or Olathe.
Riding a horse is far easier with heels than without. In my neck of the woods, heels like mine are perfectly acceptable pretty much anywhere you go. They also prevent horse by-products from getting between your socks and footwear.
Steve
Old 10-18-15, 02:56 AM   #15
ossme
Hi guys,
I go to the dunes almost weekly in my LX. Things I would recommend:
1- Tires: 15 PSI. Less if you got stuck, but not for long.
2- Center diff should be locked.
3- 4HI (with 1st - 3rd gear) when driving and 4LO with crawl control when stuck. Alternatively, 4LO with 4th to 6th gear would work as well.
4- Turn the side airbag off.
5- Turn the Air suspension off.
6- Unless you are stuck, keep the traction control off.
Good luck.
ossme is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
codeX's 'new' 2001 IS300 daily driver - an ongoing resto-build. codeXsupra Build Threads 5 02-27-16 06:21 PM
02 Sc430 VSC ON and OFF Lights no Code!! Rahstyles SC430 - 2nd Gen (2001-2010) 20 10-01-15 08:53 PM
Beach driving TGRaboo The Tire Rack's Tires, Wheels & Brakes Forum 4 01-31-10 06:44 PM
is FWD better than 4wd in mud, sand.... ssmoked Car Chat 5 08-22-08 01:31 PM
Scraped rear bumper. What should I do? Phu SC430 - 2nd Gen (2001-2010) 4 08-12-02 07:28 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
  • Ask a Question
    Get answers from community experts
What's your question?
Send
