LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Fuel Sender Failure
Old 07-14-12, 07:30 AM
DarkStar12
DarkStar12's Avatar
Post Fuel Sender Failure
Starting this thread, as I had a fuel sender failure a couple of weeks ago. 60k mi.
Basically: freeway driving, fuel gauge read 1/8 tank remaining, computer indicated "10 miles till empty" but the car ran out of gas. Fuel sender, in the fuel tank turned out to be the malfunction.
Towed to the dealer...they had never, ever seen this before and were very apologetic.
I get the car back next week, just want to bookmark this thread in case any members (God forbid) have this problem now or in the future.
I still have faith in my Lexus, but want to share as this failure was very unusual, and hopefully over time we can identify a trend and use this thread for information if need be.
DarkStar12
Old 07-16-12, 09:08 AM
ggebhardt
ggebhardt's Avatar
What caused you to look at the "miles remaining" as I seldom do.
Old 07-16-12, 09:12 AM
DarkStar12
DarkStar12's Avatar
I seldom use that function as well. I checked it while I was sitting on the side of the freeway waiting for the tow truck.
Old 07-16-12, 06:00 PM
REDHORSE
REDHORSE's Avatar
I use it all the time. I find it very conservative.
Old 11-23-15, 05:59 PM
beaunoz
beaunoz's Avatar
The fuel sending unit crapped out on my 2009 LX570. Just got it back today. My first indication was the lack of a "Low Fuel" light which usually triggers around 240 miles on the trip odometer. The wife ran the fuel too low (twice) causing the inability to start in the parking garage. She mentions that low fuel light never came on. Eventually the LX stalled on her in heavy traffic and had to be towed to the Stealership. Keep in mind she had about 40% fuel remaining when it stalled.
Lexus diagnosed in stating the fuel sending unit died completely. Lexus ended up replacing both the fuel sending unit along the fuel pump (for preventative measure).
Parts/Labor Costs:
Fuel Sending Unit - PN 83320-60580 - 154.46
Gasket - PN 77169-02050 - 3.22
O-Ring - PN 90301-A0021 - 3.22
Fuel Pump - PN 23220-50271 - 348.01
Labor - 440.83
#### Total: About a grand (Got eeeem!!!)
//BeauNoz
2009 LX570
2006 SC430
2003 RX300
Old 02-26-16, 02:14 PM
Chauffeur
6th Gear
Chauffeur's Avatar
From your post, it sounds like Lexus performed the needed repairs for free. Is that true?
I ran out of fuel today. The gas gauge at the time indicated that I had 1/8 of a tank left. A low fuel light was not present. Yep, she was empty. Swallowed 24 gallons once I got it to the pump.
Happened in the Costco parking lot. Do you have any idea what its like to push this 6000 lb beast up a slight slope to their gas pump? Fortunately, two nice folks helped out. No need to go to the gym today.
Symptoms were the same as DarkStar12, except my 09 has 112K on it. Might be part of a trend?
Old 02-26-16, 04:56 PM
DarkStar12
DarkStar12's Avatar
Sounds like an identified weak spot. One of very few on this rock solid vehicle. Mine was taken care of under warranty.
Old 04-05-16, 08:04 AM
tiguy99
tiguy99's Avatar
After they fixed, Did the problem ever happen again?
Old 04-05-16, 08:49 AM
DarkStar12
DarkStar12's Avatar
*sound of knocking on wood* so far, no more issues with the sender.
Old 04-05-16, 11:28 AM
hankinid
hankinid's Avatar
I'd check mud to verify it is indeed "an identified weak spot"...I would not call 3 occurrences since this thread started in July, 2014 a trend.
I'd say if you need a yellow light to tell you gas is needed, maybe use the good ol' fuel gauge as a backup. It's similar to the TPMS where you have a backup with an air hose and pressure gauge.
If my wife ran out of gas twice because the only indicator she knows is a yellow light, we'd probably discuss that issue.
Old 04-05-16, 01:16 PM
DarkStar12
DarkStar12's Avatar
Thats 3 occurrences of members who are on this board. I'd call it more than a fluke. Not sure why you are defensive?
Many if not most LX570 owners do not browse this forum.
In my case the fuel gauge showed 1/8 tank left, plenty for me to theoretically get from work to a gas station. The yellow light had nothing to do with what happened.
Old 04-05-16, 04:04 PM
hankinid
hankinid's Avatar
I'm not defending anything. If you feel it's a trend, that's OK...I simply disagree.
I would call Toyota's recall of series 100 LX's for both trailer electrics and HID issues trends.
Steve
Old 04-05-16, 04:16 PM
DarkStar12
DarkStar12's Avatar
Fair enough.
Also, exhaust headers on the 100 were a known issue.
Old 04-05-16, 05:47 PM
hankinid
hankinid's Avatar
Fair enough.
Definitely. As were / are my 2000 2-pinion front diffs and transmission issues.
Old 05-31-17, 09:59 AM
beaunoz
beaunoz's Avatar
No, they didn't repair for free. I had an extended warranty that covered the repairs.
Oldmanb777
GX - 2nd Gen (2010-2023)
01-24-22 10:20 PM
mlo1956
NX - 1st Gen (2015-2021)
07-02-17 01:28 PM
6.0PSD
RX - 1st Gen (1999-2003)
41
11-23-16 07:23 AM
martini84
12-21-15 09:42 AM
acenase
Performance & Maintenance
08-31-07 07:02 AM
Quick Reply: Fuel Sender Failure
