Questions on buying a 2001 LX470
That price seems close to being fair . The Ahc can be tested by turning it to high shut the engine off. Then see if it lifts up and hold its pressure , being all four corner are at a even height . See if its blinking low normal or high will usually state where the problem at. The timming belt issue nust go on lexusdriver and imput the vin itll tell you all the service record. Then if you have concern just call the dealer that it was serviced at . Im almost sure that if one can afford this truck new ,they will do the maintenance and timming belt is not a option . If your talking about towing. I just towed a 5k lbs trailer for 4 hours in the hills of nc and sc to Atlanta with no issue . The lx is that great of a rig ,its so heavy its unnoticable ,and the 4.7 tundra motor does great . its got almost a 1k lbs tongue limit so its really good . I have seen people tow more than its recommended weight, dued to Toyota underwieght their towing capacity.
The AHC needs to be tested via Toyota software. The Lexus website will give you maintenance info, but only for services from a Lexus or Toyota dealer.
Gray2000LX
07-26-17 02:32 PM
