1997 lx450 wet passenger floorboard
Help please, I know on other cars the sunroof drains come out behind the front tires in the wheel well, & there are two holes in the same place on my 450 as well; so I assumed the sunroof drain was clogged and did all the steps to unclog it I thought. I poured water in the sunroof and it came out pretty as you please on both sides somewhere near running boards, but not out of what I thought was the drains. It only happens when it rains heavy, but I cannot figure out where the water could be coming from? Please any info will be greatlying appreciated
hth
Steve
I'd have guessed sunroof drains first, so you started in the right place. Maybe you've got a leak around your windshield gasket? Either you've got on original one that's old and brittle and leaking, or maybe you had a windshield replaced and the tech didn't seal it up well enough?
kellydon09
RX - 1st Gen (1999-2003)
12-25-19 10:59 PM
