LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
'04 LX470 DRL's
Old 08-17-15, 07:56 AM
mrhenry
mrhenry's Avatar
Question '04 LX470 DRL's
Hi All,
I need a little help. I'd like to change my DRL bulbs to 100 watt from the 60 watters that are in it now. I think I did it in my '01 without any problems. Can anyone offer some advice.
Thanks
Old 08-17-15, 08:25 AM
hankinid
hankinid's Avatar
It's easily done, just get the 100w bulbs and stick them in the high beam sockets. When the DRL's are on, the electrical system simply puts both lights in series, so each light now gets half the normal wattage.
hth
Steve
Old 08-17-15, 02:00 PM
mrhenry
mrhenry's Avatar
Hi Steve,
Thanks for the help. However, my intent is to get the extra brightness from the 100 watt bulbs. Won't I lose that if i do what you suggested?
Old 08-17-15, 03:22 PM
hankinid
hankinid's Avatar
Hi All,
Thanks
hth
Steve
Hi Steve,
I'm a bit confused...
Your first post..."I'd like to change my DRL bulbs to 100 watt from the 60 watters that are in it now."
So, I suggested swapping the high beams from oem to 100 watt'ers.
Since the DRL system puts the bulbs in series when the DRL's are on, your current 60 watt bulbs are running at 30 watts each, and the 100 watt bulbs you want to change to will run at 50 watts each...i.e., they will be brighter than the oem bulbs.
If you feel you need more brightness during daylight hours, just turn on the headlights.
Steve
Old 08-17-15, 03:52 PM
mrhenry
mrhenry's Avatar
Talking
Now I understand.
Thanks Again
Old 08-18-15, 11:43 AM
hankinid
hankinid's Avatar
Now I understand.
Thanks Again
You're very welcome.
One thing to think about...high beams in your LX use reflector housings. If you're doubling the wattage, you may be blinding oncoming cars at night unless you're careful to re-aim the lights as required.
In my case, I updated the projector low beams to HID bulbs (DDM Tuning...google). The improvement in light throw essentially made the high beams redundant, and I'm not throwing light into the other lane.
I disconnected the DRL circuit completely, but I continue to use low beams on 2-lane roads.
Steve
Old 08-18-15, 11:59 AM
mrhenry
mrhenry's Avatar
Default High Beams
I will certainly do so, and thanks again for all the help.
Old 08-30-15, 03:11 PM
Arraco
Arraco's Avatar
100 watt draw really doesn't translate into any real discernible brightness - just more heat and lower bulb life.
Old 09-01-15, 08:44 AM
hankinid
hankinid's Avatar
I'd opine that's more of a bulb / reflector combination than the bulb itself...
...E.g., the same bulbs are used for high beams in both my '01 LX and new-to-me '13 Land Cruiser. High beam lighting in the LX is dismal; replacing the low beams with 50 watt HID bulbs made the high beams redundant.
The Cruiser has excellent lighting with the oem high beams.
Without question, the best bulb performance I've seen is using GE 4309L landing light bulbs for driving lights...100 watts, flat lens, great reflector. But they need to be added as driving lights.
hth
Steve
Old 10-14-15, 06:54 PM
OTFIN843
OTFIN843's Avatar
Any way of running that power to your turn signals? when ignited they are quite bright. The Tacoma/4-runnner look.
Obviously wouldn't want to loose the turn signal effect though.
tucker21
Lighting
07-09-13 08:40 PM
20GS300
02-19-13 04:17 PM
HAiS250
02-22-12 04:45 PM
italiandud
12-08-07 11:33 AM
ozeki
Lighting
05-27-03 03:59 AM
Quick Reply: '04 LX470 DRL's
