LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Mark Levinson audio dead
Old 01-04-15, 12:34 PM
ChuckB669
ChuckB669's Avatar
Default Mark Levinson audio dead
My Mark Levinson audio system died in my 2002 LX-470. No CD, no radio, no antenna. Two questions. 1. How can I tell if the ML amp is bad or it's just the control panel? and 2. If it's the amp, some time ago a forum member mentioned a company who sells new or repaired ML amps on an exchange basis at a much cheaper cost than new or on EBay. Anyone have that info?
Couldabeen (01-12-20)
Old 01-12-15, 10:19 PM
some
some's Avatar
Default Mark Levinson fix
I decided to try to fix my ML amp in my ES330 myself.
I found one tiny component causing the problem: A blown capacitor. It was clearly rattling around the case and the internals were flopping around as well.
I identified the part number as "Nichicon PW series 39uF 16V aluminum electrolytic capacitor"
I will order a couple and fix the one that was out as well as possible the one next to it.
The amp was in my trunk. If you can find your amp and choose to repair, just know that you'll need a Torx T10 and a 5/16 socket wrench to open the amp.
There are screws under the Mark Levinson label on the amp
Hope this helps.
If you want to save time but spend a little more money,you can find your part number and replacing it with an identical model from one of the many sites on the web.
The following 2 users liked this post by some:
Denvergal (03-22-18), lexus600hl (12-14-16)
Old 04-14-15, 09:39 PM
neelnaik
neelnaik's Avatar
I know this is an old thread, but if your amp is dead, it will likely chirp when you try to play anything. See video linked to below.
Usually when control panels go out, you start losing the ability to do certain functions, like change or seek radio stations or tracks on a CD.
Old 12-14-16, 04:03 PM
lexus600hl
lexus600hl's Avatar
Hope this helps.
Very useful! As I had written in the other thread.. United Audio has been charging a lot.. for a simple fix.. Glad you figured it out.. I hope more people would try to fix this.. There are a couple of electronic repair companies online..
http://www.desertaudiospecialists.com/our-service
Almost any electronic repair tech should be able to fix this for $100 to $200 max.
Old 12-14-16, 10:24 PM
USLEX
USLEX's Avatar
Hope this helps.
lexus600hl, referred me to your post. I didn't see a follow up to your repair attempt. Please how it went and if you had success. Thank you.
Old 12-20-16, 07:54 PM
ChuckB669
ChuckB669's Avatar
For years I thought either my amp or control unit died in my 2002. Then a few weeks ago, I accidently pushed the ON switch when going over a speed bump, and Magic! The antenna went up and the CD player began playing a disc. Functionality lasted for about 2 weeks, then just as suddenly, it stopped working again. It's still dead with no audio, no antenna control - nothing. Well, at least I know that there's nothing wrong with the Mark Levinson amp. I think I've got a loose (not on the amp - I checked those connectors) or shorted wire somewhere. And from what I've read on this forum, it could be anywhere...
Old 01-23-17, 06:37 PM
eng2000g
eng2000g's Avatar
Default I am having this same issue
I am having this same issue. Did you ever resolve this issue?
Old 10-11-17, 02:06 PM
vj70
vj70's Avatar
So, I'm just reading this, I know it's late but chuckb669 and eng2000g, not sure if you got the problem resolved, but years ago tht was a grounding issue. If your radio came on from the bump then it may have grabbed enough ground to come on. Check the ground under the hood that connects to the car and see if it has a good clean contact. Hopefully you guys both have the issues resolved
The following 2 users liked this post by vj70:
Couldabeen (01-12-20), Denvergal (03-23-18)
Old 04-03-20, 10:55 AM
Couldabeen
Couldabeen's Avatar
Default Ml amp
To all concerned, this Desert Audio DOES NOT repair Mark Levinson Apms.
Old 06-27-20, 01:07 PM
jmsmiff
jmsmiff's Avatar
Amp Died on my 07 460L w/ ML. I guess I'm not too upset my car has 132k. Went to a local shop who quickly told me there was nothing they could do. They told me to bring them a new amp and they would install for $350....I almost laughed at him...In fact I did but I had my mask on. Anyone have anything new on this issue?
Old 06-28-20, 04:34 PM
Couldabeen
Couldabeen's Avatar
I just had my Amp repaired by a place in New Jersey, it cost me $550. If your interested here is their contact number. They are legit. 862-849-8799. Dont let anyone do the install amd remove for you, you can do it yourself. In your trunk on the right side is a compartment, you will have to remove the trim around your trunk latch to access it, but carefully access the qtr panel from your trunk on passenger side and there are approximately 4 plugs to unclip from your amp that you will see when you look into that corner and 2-3, 12mm screws to take out and you can remove the amp. You will have to take it out of the bracket before shipping. The small unit atop that bracket you cam plug back into your trunk if you want access to your interface to adjust your heat, music, etc... I hope that's helpful. I was told by the Lexus Dealership that they would have done a swap for me on that amp on Sat. But I am not so sure that's true. Probably woulda cost me an arm and a leg. I live in Washington State and the Dealership was Bellevue Lexus. You can give them a call to follow up before spending the 550. Maybe you will get motion where I did not. Anything is worth a try. I feel your pain my friend. Lol.... it SUCKS. Hope all of that helps ya. Have a Hapoy 4th of July.
Old 06-28-20, 04:35 PM
Couldabeen
Couldabeen's Avatar
Sorry about all of the grammatical errors. Lol... I just saw that.
Old 12-03-21, 11:33 AM
RFTowers74
5th Gear
RFTowers74's Avatar
My '07 LS460 started that sound last night. A Lexus tech removed the fuse from the front passenger side but now there is NO sound whatsoever. I'm trying to weigh the advantages of purchasing a refurb or removing mine and sending it in for repair.
Can you shed some light on the pros and cons?
oscarls460
Today 09:56 AM
luciush
11-02-11 04:03 PM
Nauticalx
06-21-09 09:07 AM
dacecil
11-09-08 07:18 PM
Quick Reply: Mark Levinson audio dead
