although mine is a 2001 landcruiser, I thought I could chime in. Just turned over 200,000 miles. All service either at Toyota or Lexus dealerships at 5000 miles. Nothing major other than synthetic oil changes, brakes, timing belt every 90k. Had the water pump changed out for the first time at 180k and tech said the pump was still in good shape-no leaks what so ever. Tires every 80k or so-just put on another set of Michelins. Mine has mostly highway miles -swap back and forth from 93 to 89 octane with not much noticeable difference between the two. I had the front end repacked a few times but not recently-tech checks play in front end and advises to hold on to my money since I don't do any off roading with it. Also, I change tranny fluid (drain and refill) every 30k. Plan on keeping it another few years.
Mechanically mine 01-LX470 is good at 140K. I need a new upper tailgate .....rust issues
178,000 miles, still looking good bought it several months ago. Had some normal maintenance done, dealer took several thousand off asking (started out at $9600) since AHC was gone, had Slee replace it, ordered replacement leather for the front seats, hope to have it for many years. Love the car ...
Our '01 LX just turned over 190K. No leaks, no unscheduled maintenance. She just got a timing belt and water pump; new rotors and pads all around and new shoes in the rear. Bled the brakes completely including the ABS assembly. I'll grease the driveshafts this weekend and change diff's and trans case.
