Sun Roof mis-aligned
I noticed that the back of my sun roof is not perfectly aligned with the roof line. When i push on it from the inside it goes up and aligns properly so i was wondering if there is an "easy" way to adjust it so that it stays flushed permanently or does this requires a trip to a body shop?
here it is...
Initialization Procedure
NOTE
Before performing this initialization procedure:
^ Make sure that there is no foreign matter on the guide rail.
^ Make sure that the guide rails are not deformed.
NOTE
^ Do NOT switch any electrically powered systems ON and OFF during initialization.
^ If battery voltage fluctuates by 0.5V or more, initialization will fail.
^ Permanent ECU damage will occur if power is disconnected while the moon roof motor is operating.
^ Do NOT move the vehicle during re-initialization.
^ Do NOT apply strong force to the vehicle during the re-initialization, such as closing the door.
Before beginning this procedure, make sure the moon roof is fully closed.
NOTE
If the moon roof will not close automatically use manual mode to close the moon roof. Quickly press and release the switch until the moon is closed.
1. Switch ON the ignition(IG) by pressing the START/STOP button twice or turn the engine key to IG position.
2. Push and hold the TILT UP switch until the moon roof reaches the full tilt up position, then release the switch.
NOTE
The tilt up position is the starting point for the moon roof motor to re-learn the positions.
3. Push and hold the TILT UP switch again. After approximately 10 seconds, moon roof will begin the initialization procedure. DO NOT release the
switch until the procedure is complete. The moon roof will tilt down, slide open, slide close and stop at the fully closed position. At this point the
initialization is complete and the tilt up switch may be released.
NOTE
If the TILT UP switch is released during the procedure, the buttons may not operate properly. The moon roof will have to be operated manually to start
the procedure over again.
NOTE
NOTE
NOTE
NOTE
NOTE
There's a similar process to follow to reset the power seats when the battery has died (or been disconnected) and you find the seat memory buttons don't work anymore & you can't save a setting. There are instructions in the owners manual on the process. You're effectively retraining the computer so it knows where the seat is by moving it all the way back & forward. When the battery dies, the computer won't know where the different mechanically moving parts like the seats and the sunroof are in their tracks & range of motion. The reset procedures let it learn the limits of movement and lets the computer know where the seat or sunroof is.
lexusscturbo
CL of Southern California
12-19-09 03:26 PM
