08 LS 460 Dash Light Help
Old 05-26-15, 07:06 PM
mdorn98
mdorn98's Avatar
Default 08 LS 460 Dash Light Help
Hello again and thanks in advance for the help. A little over a week ago I had my battery go low and set off several brake warning lights on the dashboard. I have a very trusted mechanic and had him look it over. There were no issues whatsoever with the braking system and the lights simply occurred due to a drop in battery voltage. My question would be how to clear the lights. I have seen various people use something called a techstream and was wondering if this would be viable in my situation. If so could someone point me in the direction of the most updated version of the tech stream as well as a possible tutorial. Below for reference is a picture of the lights that were set off on the dashboard(circled). The dash isn't mine just one that I found but the four lights in question are the same THANKS!
Old 05-26-15, 07:59 PM
roadfrog
roadfrog's Avatar
Did you replace the battery? I would think that these lights would go out when the situation was corrected.
Old 05-26-15, 09:08 PM
mdorn98
mdorn98's Avatar
I did replace the battery and checked that it had the proper voltage however after some research I discovered the lights don't correct themselves once the battery is fixed which is why I was wondering if the tech stream would fix the issue
Old 05-26-15, 09:30 PM
roadfrog
roadfrog's Avatar
Hmmm....I wonder if you do the reset as follows:
while holding down the reset button (for the odo) and then pressing the "start/stop" button. That often works for the VSC errors.
Old 05-26-15, 10:21 PM
mdorn98
mdorn98's Avatar
Thanks Roadfrog I'll definitely try that
Old 05-26-15, 10:41 PM
roadfrog
roadfrog's Avatar
Let us know. If that fails, then I'd try an OBD scanner to see if you can reset. Techstream, definately will, but it's a costlier option. FWIW, your Toyota dealer can do this and will be cheaper (and perhaps free if you have a good relationship with them as I do).
Old 03-27-16, 10:22 AM
Obayda
Obayda's Avatar
Default Did you solve your problem.
Just wounding to know if the problem of the dashboard had sorted out. As I got the same problem on my lexus and would like to know how can I solve this issue
Old 03-27-16, 02:34 PM
greg3852
greg3852's Avatar
Set the car to Trip A. Turn off car. While holding reset, press the start button 3 times (i think) Keep your foot off the brake
Old 08-16-16, 08:02 AM
pingyy
pingyy's Avatar
just wanted to follow up on this response were i got the error message w/ the VSC and the reset did work.. Thxs ..
Old 08-16-16, 09:34 AM
GR6RR
GR6RR's Avatar
Carista app helped me clear these lights just the other day. I didn't realize there were these steps to clear them as well. Good to know...
Old 08-16-16, 10:33 AM
tofu
tofu's Avatar
Few years back I had a problem with my battery and it threw brake, ABS warning lights on my dash too. Scanned and got these codes C1203, C1336, C1345 and C1392.
I took my 08 LS to a local shop and they re-calibrated or re-learned the ABS system with their computer.
Old 01-30-17, 07:09 AM
mccoymarka
mccoymarka's Avatar
Thank you. Same issues above. The suggestion below worked for me to correct VSC Systems errors when I changed my battery. Thank you. [ RESET BUTTON ODO + START/STOP ENGIN]
Ledfam
09-04-18 11:48 AM
singletary
12-21-17 04:28 PM
JamesGS
12-01-17 12:19 PM
JiggsHall
02-10-16 09:05 AM
Quick Reply: 08 LS 460 Dash Light Help
