Moonroof problem
Moonroof problem
I have a 2012 LS 460
When the moonroof is closed the aft section is not flush with the roof. It's about 1/4 inch low
I don't think this is normal
Any comments?
Thanks
Any comments?
Thanks
You probably need to reset the roof. This is accomplished via the moonroof button. I think this is how: With the ignition in the on position and the roof closed, push and HOLD the sunroof tilt button. The sunroof will tilt open, tilt closed, slide open and slide closed. Then you may release the tilt button and the sunroof will be reset.
Moonroof problem
Thanks for the reply. I went into the owners manual and tried to reset it. The manual says to hold the down switch for 10 seconds. It will cycle the moonroof. Nothing happens. I tried it with power.
I'm not sure if the moonroof is covered under the warranty as I might have to bring it in
Moonroof closes almost and stops
My moonroof closes to almost finished and stops. I have to help it finish closing. Any ideas how to fix it? Maybe add some silicone spray or something.
