Help with AFS!!!
Old 02-19-15, 08:37 PM
ShahG
ShahG's Avatar
Default Help with AFS!!!
Hey Guys,
So here is the deal. I got the lights retrofitted last week. All from TRS.
Now comes the AFS. The mods to the projector were only Clear Lens.
My installer said there is only one switch for the AFS, which he showed me.
The first time we installed it, The moment you started the car, the AFS check came on. Lights Adjust the way they are suppose to on Start, But the left light swiveled to the right and then both dropped down. We opened the light again and checked the connector was tight inside the light. Second time around, It does not display the AFS on start. But I took it around the block. As soon as you turn to the left, The lights will swivel to the left, but right after they come back, I get the AFS light, and both projectors go right down. I am able to shut off AFS during start up as there is no issues until I actually approach a turn. The right side is good, no error codes from there. However when hooked up with OBD, it gives me a B2412, which translates to left swivel motor. I will be going back and what my installer suggested is we directly wire the connector inside the light, see if it works out.
If you guys can help out please, That light is ridiculously annoying, flashing every second.
On the other hand, the lights came out sexy! I get compliments when backing into my driveway to DD DriveThru's! They look insane and came out really good. Very Happy.
Item list
Morimoti RGB Angel Eyes, Low Beam, 100mm, High Beam 90mm
XB Led Strip
STI Clear lens
Strip wired to Parking, not DRLs.
YES THE CAR IS DIPPED. Color is going to be Gulf Blue, Its not finished yet so hold on to your comments!
Old 02-20-15, 08:57 AM
jbrittmart
jbrittmart's Avatar
I feel your pain.
Dumbest thing ever. No solution yet except to replace the sensors.
Old 02-20-15, 08:34 PM
roadfrog
roadfrog's Avatar
I get almost the same code....except it's the right swivel motor. Let us know what you find out.
Old 02-20-15, 09:16 PM
Lavrishevo
Lavrishevo's Avatar
Nice looking headlights. BMW style. Too bad you can't dump that front license plate. I have two screw hole in my front bumper from the previous owner. Really pretty pointless that some states require front plates.
Old 02-20-15, 10:25 PM
ShahG
ShahG's Avatar
Do your headlights aim down after the Light comes on?
Old 02-21-15, 06:41 AM
roadfrog
roadfrog's Avatar
Yes. The lights go through their usual, up/down, side/side movements after start up and then drop down lower than they used to. Then, the "AFS Off" lights starts to flash.
Old 02-28-15, 01:32 PM
ShahG
ShahG's Avatar
Originally Posted by jbrittmart
I feel your pain.
Sensors? Can you elaborate please?
Old 02-28-15, 01:33 PM
ShahG
ShahG's Avatar
I feel your pain, I can still shut off AFS and it wont take my whole display up. And the light wont come on unless I turn the Headlights on, so kind of a plus for me.
landman
03-24-21 03:28 PM
scottmcc
06-04-18 10:18 AM
ZaxF
04-04-14 05:03 AM
d6500k
02-04-07 11:15 PM
shikbas
09-12-05 03:26 PM
Quick Reply: Help with AFS!!!
