Possible wheel choice LS600
Came across a decent deal for a set of 22" wheels for my LS600. Originally fitted to a Range Rover, they are 22x9.5 with 32mm offset. Now from browsing the wheel FAQ, it seems as if these would fit ok, but im not too sure how they would look on the car with the same size lip front and rear. Most of the wheels I see have little to no lip or are staggered with more in the rear. Here are pictures of them. Any comments or suggestions?
Make sure the hub bore is at least the 60.1mm for our cars. If it is larger than 60.1mm and you get these wheels, I would run the appropriate sized hub rings to better eliminate chances of any vibration
These are much bigger than the 60.1mm hub bore so you will need a 72mm to 60.1mm hub centric ring for the wheels to sit flush on the hub. Double check the 72 number..but I believe its close. Also, you should be ok in rear but you may need a 3mm spacer for the front to clear the control arm. It may be fine but be prepared for that since these are 9.5 wide with 32 offset. The rears could probably use a 5mm spacer to get you a less sucked in look. A 265 tire should help with that and give you a smoother ride since they are slightly taller than the 255 but 10mm wider. Also you must get range rover lug nuts. These wheels require them..no exceptions. I would run 255 or 265/30/22 all around. I did extensive research on Redbourne wheels before I got my Vossens on my 600.
jjbenzo
08-23-09 12:26 PM
SUPRAboy80
Wheels, Tires & Brakes Forum
10-05-05 12:57 PM
