Anyone installed Avest Led side mirrors?
Old 12-15-14, 09:37 AM
  #61
Dirteeboy
Dirteeboy's Avatar
Originally Posted by lbintab
I posted this in another thread. When the turn signal goes off the white light turns off. That's bult internally to the light. Then when the flashers turn off the white light will turn back on after a few moments.
http://instagram.com/p/uxAXwqO3pZ/
Finally got my set back from the painters. How was the white light wired in? Directly to the light switch?
Old 12-15-14, 10:13 PM
  #62
lbintab
lbintab's Avatar
I don't know. Our wiring guru at our shop did it. From what he said it was a little complicated.
Old 12-16-14, 09:16 AM
  #63
roadfrog
roadfrog's Avatar
I will be wiring mine to a source that provides 12v when the lights are on. That may be a wire to a parking light, or under the dash or underhood fuse panel on the passenger side.
Old 12-16-14, 02:25 PM
  #64
Dirteeboy
Dirteeboy's Avatar
I'm wondering how the blinker turns off the white light if there both wired in or is it something within the light
Old 12-16-14, 03:59 PM
  #65
roadfrog
roadfrog's Avatar
It's done internally.
I have finished installing my mirrors, but haven't wired them yet. I will start a new thread with DIY etc.
Old 12-16-14, 08:32 PM
  #66
Dirteeboy
Dirteeboy's Avatar
Thank you good sir, might tackle it this weekend
Old 12-16-14, 09:25 PM
  #67
lbintab
lbintab's Avatar
There was something about low constant power run throughout the car which is like a system check. When he first installed it the white light stayed on with the car off.
Old 12-30-14, 12:51 PM
  #68
FreddyG
FreddyG's Avatar
Thanks for all of the info Guys!
Ibintab, do yours come on with the headlights if they re set in the auto position or all of the time that the car is on?
These housings look Very Cool and I might have to give them a try, but wiring stuff up isn't strongly in my wheel house.
Old 12-31-14, 09:06 AM
  #69
lbintab
lbintab's Avatar
The white light comes on with the park lights. The blinker always blinks if those lights are activated with either the turn signals or hazard lights.
Old 01-01-15, 08:38 AM
  #70
roadfrog
roadfrog's Avatar
Did you ever get word on where you hooked up the wiring for them? Under the dash or ???
Old 01-01-15, 09:28 AM
  #71
lbintab
lbintab's Avatar
everything was hooked up under the dash. Where exactly I don't know
Old 01-01-15, 11:12 AM
  #72
FreddyG
FreddyG's Avatar
That's exactly how I'd want them to work! Thank You for the info!
Old 05-12-20, 07:59 PM
  #73
ALK
ALK's Avatar
I have the other design of the AVEST mirror ,this is the sequential turn signal. I got them from a clearance sale in japan . They were unpainted . I attached the instructions in Japanese . the only thing missing in the instructions is the turn-signal tap location , which is in the flasher relay pin 1 and pin 3 . Will update when installed.
NotFasty (05-13-20)
Lowenart
CT 200h Model (2011-2017)
06-19-15 03:57 AM
bozer
02-21-09 10:49 AM
GS430V8
04-19-08 06:48 PM
0l33l
SC- 1st Gen (1992-2000)
22
01-20-07 03:04 AM
omaha_lex
03-30-05 10:27 PM
Quick Reply: Anyone installed Avest Led side mirrors?
