Anyone installed Avest Led side mirrors?
Thanks sprtent for the link!!
Tried my best..but did'nt know it was against forum rules...sorry
If there is anyone ordering for and will use on car with Smoky Granite Mica 1G0 color, I would really like that I could get in on the purchase and get them painted in the same operation , and re-send the to me :-)
Regards
Arvid
Regards
Arvid
Post #11 has the wiring colors for the blinkers
https://www.clublexus.com/forums/ls4...ignal-mod.html
How to remove mirror:
This for an install in an IS, but should be semi similar:
https://www.clublexus.com/forums/is-...k-warning.html
https://www.clublexus.com/forums/ls4...upgrade-2.html
Just need the to figure out the DRL wiring
For the one dirteeboy posted a link for, it does matter. See Arvid's post for explanation. That style just doesn't fit LHD. Believe me I was wracking my brain trying to get them to explain to me how it doesn't fit
The style you installed and I have but haven't installed does fit LHD. Some of the other Avest styles don't though (replicas of 2010-2012 ls460/ ls600 mirror covers)
Congrats on the SEMA showing BTW!
I wonder how complicated the wiring might be. Neg... pos, etc. Last time I checked polarity on a set of LED's I fried the light assembly. They were cheap lights, but I do not want to replace these at 250 dollars!
Also, does anyone know if the lights SHOULD go on with the DRL's? I don't want to hook it up that way if that isn't the norm/factory, in the newer LS' that now come with mirror lights.
My friend who wired mine said it was a little complicated. Something about how the lighting system has a small amount of voltage all the time so during a system check it can tell if a bulb is out. He figured it out though. The white light is hooked up as a parklight. Not bright enough to be dtrl. When the signals go on the white light turns off. Then when the signal lights stop after 2 seconds the white light turns back on. That feature is wired internally to the cover lights.
I may just leave the DR/Park function disconnected. Hopefully the pkg will come with some form of instructions or diagrams indicating which wire does what (there are 3 wires per mirror).
I was quoted 200 dollars to paint them from the body shop that did my deer collision damage. I can probably find a cheaper option.
