Vibration in seat
Old 10-22-14, 06:13 AM
waynedog
waynedog's Avatar
Default Vibration in seat
I recently purchased a CPO 2009 LS460. There was a vibration in my seat at 70 mph that I asked them to fix (tire balance). They have done it 3 times now, including road force balance, and the vibration is still there at 70 mph. I assume that it must not be the tires since they have done it 3 times. What else could it be? Should I take it to a tire store (is Lexus as good as tire stores at fixing problems like this)?
Old 10-22-14, 06:21 AM
sktn77a
sktn77a's Avatar
Most high-end manufacturer dealerships are actually better than your average tire store at balancing wheels. They "road-force" balance them - that's why they charge so much! Make sure your dealership did this. And make sure they balanced all 4 wheels. Of course, there's nothing wrong with trying a second shop (tire store) to do this. In your case, it sounds like something else may be causing the problem.
Old 10-22-14, 06:41 AM
Devh
Devh's Avatar
The lay people often confuses tire and brake people with mechanics. The dealership has technicians that are at the top of the food chain. They are highly trained people and in some cases have six figure salaries because of their expertize and accreditation where as the tire guy is paid near minimum wage for doing a repetitive job that doesn't require much skill.
Old 10-22-14, 07:04 AM
bsimonds
bsimonds's Avatar
Balancing tires is not rocket surgery. If they have tried the same thing three times and it hasn't fixed the problem it is time to take it somewhere else.
Old 10-22-14, 10:25 AM
dlbuckls10
dlbuckls10's Avatar
Red face
I totally agree and its hard to believe the Lexus dealership can't fix or correct your vibration problem. Something isn't right.
Old 10-22-14, 11:43 AM
sapstar66
sapstar66's Avatar
I've had that issue and it ended up being a warped brake rotor. You don't feel it in the steering wheel, cuz power steering isolates it, but that's what it was.
Hope that helps
Old 10-22-14, 12:02 PM
escapedcon
escapedcon's Avatar
Hope that helps
thanks...I have this vibration too (when coasting...no braking) after replacing my brake pads and tires. was yours when braking or just cruising?
I guess I'll have to take it back to do the rotors eventually, as well
Old 10-22-14, 12:19 PM
waynedog
waynedog's Avatar
When I purchased the car they replaced the rotors due to vibration when braking. That solved the braking vibration problem but the vibration when cruising at 70 mph continues (was there before the rotors were replaced)
Old 10-22-14, 02:56 PM
escapedcon
escapedcon's Avatar
yeah...that's what I have too but this after replacing my tires...weird. mine is very subtle but I feel it nonetheless
I even read somewhere on the CL forums that someone pinpointed the vibration as to a problem with one of the engine mounts. I guess it could be a variety of things
Old 10-22-14, 04:59 PM
sktn77a
sktn77a's Avatar
Can also be due to worn control arm bushings but you can usually feel that in the steering wheel in addition to the seat.
sam12345
Wheels, Tires & Brakes Forum
01-10-13 09:09 PM
stvincent
07-09-10 10:44 PM
MELODY7
13
10-07-08 11:24 AM
rpx13
GS - 1st Gen (1993-1997)
10-22-04 08:34 AM
theanimala
12-28-01 11:11 PM
Quick Reply: Vibration in seat
