The story of my life, P0338...
Old 09-11-14, 07:37 PM
Agamimno
Agamimno's Avatar
Default The story of my life, P0338...
Hello everyone,
I have the P0338 and this is what I've done so far with no success :
Changed the battery 2 times.
Changed the crankshaft sensor also 2 times.
Changed the alternator.
Checked the cables for the sensor.
All that and I still get the VSC System Check with the same code.
If anyone could help me please, I am about to drive this car over a cliff!
It's an LS 460 2008 with a 89k miles.
Thanks for your help and support.
Old 09-11-14, 07:41 PM
greg3852
greg3852's Avatar
Are you personally doing the work, or the dealership?
Old 09-11-14, 07:44 PM
roadfrog
roadfrog's Avatar
These are the common causes:
- Faulty crankshaft position sensor
- Crankshaft position sensor harness is open or shorted
- Crankshaft position sensor circuit poor electrical connection
- Signal plate may be damage
- Starter motor may be faulty
- Starting system circuit
- Dead or weak battery
A weak starter can trigger this code. Looks like you've already covered the other obvious culprits, so replacing the starter would be my next step.
Old 09-11-14, 07:47 PM
Agamimno
Agamimno's Avatar
In a lexus specialist service centre
Old 09-11-14, 07:49 PM
Agamimno
Agamimno's Avatar
I thought that the starter ends it's part after starting the car, dose it still operational even if the car is running?
I am thinking of changing the signal plate, this is the only thing that I haven't done.
Old 09-12-14, 07:57 AM
roadfrog
roadfrog's Avatar
Apparently the weak starter can trigger the code before the car actually starts because it's part of the starting circuit.
Old 09-12-14, 11:52 AM
Agamimno
Agamimno's Avatar
I always gets the code (after resetting) while moving with the car, usually 2 hours after the reset, some times it last for a day or two, but I never gets it right after i start the engine.
Old 09-12-14, 02:11 PM
roadfrog
roadfrog's Avatar
Rather than throw parts and money at it then, I would at this point let a Lexus dealer take care of it. In the long term, it may be cheaper.
Old 09-12-14, 03:27 PM
Agamimno
Agamimno's Avatar
I would but it's not possible since I live in dubai (GCC) and the dealer only service GCC spec cars, mine is American import :/
tpeeler099
01-10-14 03:09 PM
jbalian
ES - 5th Gen (2007-2012)
07-04-13 09:07 AM
ninjarico
06-08-09 07:13 AM
JOHNBRAY11
RX - 1st Gen (1999-2003)
03-09-07 12:43 AM
Quick Reply: The story of my life, P0338...
