LS460/600hl Camber kit
Old 07-25-14, 09:48 AM
lieup
lieup's Avatar
Default LS460/600hl Camber kit
My buddy sent me these brackets camber kit for me to test in the US. Anyone would like to test it out?
Kit comes with
4 brackets and couple nuts and screws
1 bracket for each side
ONLY fits LS460(L) RWD ONLY
Attached Thumbnails LS460/600hl Camber kit-photo.jpg
lieup is offline
Old 07-25-14, 03:05 PM
Nat
Nat's Avatar
I'll try it.
Nat is offline
Old 07-25-14, 03:10 PM
1Putt
1Putt's Avatar
They look like the OEM optional brackets for the front control arms that change the camber only very slightly more positive. I have them installed on my car, it moved the camber maybe .25* more positive
If they're not the OEM pieces, maybe these alter it even more ?
1Putt is offline
Old 07-25-14, 04:41 PM
is150
is150's Avatar
I'm surprised figs hasn't come out with something yet. Wishful thinking I guess.
is150 is offline
Old 07-25-14, 07:42 PM
Nat
Nat's Avatar
I contacted Figs about 6 months ago, they said they had someone working on it but not enough resource.
Nat is offline
Old 07-26-14, 03:45 AM
CJITTY
CJITTY's Avatar
If those are the oem brackets, I did a complete writeup of these about 3 years ago in my Tanabe Experience thread located in the FAQ thread. Includes before and after alignment specs etc
CJITTY is offline
Old 07-26-14, 05:50 AM
1Putt
1Putt's Avatar
They look like the OEM brackets but they are aftermarket I believe. Seems like they replace one bracket at each corner... FL, FR, RL, RR. Interesting...
1Putt is offline
Old 07-26-14, 08:18 AM
lieup
lieup's Avatar
Yes, these brackets are aftermarket.
I guess it supposed to change the fulcrum position of the arm and changes the camber.
Where did I get it? http://www.badmoon-racing.jp
lieup is offline
Old 07-27-14, 03:48 AM
broken_tsi
broken_tsi's Avatar
How much of a change is it supposed to have?
broken_tsi is offline
Old 07-27-14, 07:13 AM
is150
is150's Avatar
May be a dumb question. But why couldn't we just shim the factory ones?
is150 is offline
Old 07-27-14, 10:57 AM
robert1408
robert1408's Avatar
They can't be shimmed because they are bolted to the car through their sides so that shimming would prevent the long cross bolts from lining up. In the pics you can see the crosswise tubes those long bolts go through.
robert1408 is offline
Old 07-27-14, 01:14 PM
lieup
lieup's Avatar
Default camber change
They said (0.5 to 1) degree!
lieup is offline
Old 07-27-14, 04:03 PM
CJITTY
CJITTY's Avatar
Seems like slightly better than the alternate 2mm oem brackets. Here is the thread with alignment specs on those with tanabe springs https://www.clublexus.com/forums/sho...d.php?t=597604
CJITTY is offline
Old 07-27-14, 04:13 PM
robert1408
robert1408's Avatar
Thats some real useful camber change! The Lexus ones are only a 2mm offset and intended only for minor alignment corrections involving steering pull. They give only 1 or 2 tenths degree camber or caster change. These new brackets must have close to 8-10mm offset.
Old 07-27-14, 08:29 PM
is150
is150's Avatar
Yeah I forgot about the bolts that attach threw the side.
How much for a set of these?
is150 is offline
Quick Reply: LS460/600hl Camber kit
