07 Domelight wire color and location?
Old 06-27-14, 05:28 PM
macjac69
macjac69's Avatar
Default 07 Domelight wire color and location?
Searched, couldn't find a definitive answer so here goes....
Any one tell me the domelight wire color and location in an 07 LS 460?
Old 06-28-14, 05:28 AM
Shibumi1
Shibumi1's Avatar
What's your intent?.. there is no actual dome light wire its controlled thru lin bus.. so your best bet would be tap the wires at or near the closest bulb..
Old 07-01-14, 03:46 PM
macjac69
macjac69's Avatar
Wanting to wire in suspension lighting that will work in conjunction with the domelight ie: illum when you disarm, walk close to car w key fob...
Is there a how to on taking the domelight housing apart? I guess I could tap into there if I could get to the wires?
Old 07-04-14, 05:30 AM
Augs300
Augs300's Avatar
why don't you tap into fotwell lights. They seem to do the same thing.
Old 07-04-14, 06:21 AM
Shibumi1
Shibumi1's Avatar
That was goin to be my solution for it...but I wanted to know how he intended to use it 1st.... simple solutions are usually the best..
Old 07-06-14, 05:41 PM
macjac69
macjac69's Avatar
Well I've gotten the hard part done. Suspension lighting is installed. Found domelight supervision is on LIN bus in this car.... Not neg. output like my IS-250... Tried tapping the footwell but it's a constant 12v so all it does is turn on the lights constant. Oh by the way suspension light input is 12v +...
I managed to find a 12v - domelight wire near the driver fusebox on my IS and I used a relay to switch it and it works perfect the lights come on when I get close to the car with the key, when the doors are open and using the Fob to unlock really looks good.... I'd like to hv the same on my LS! Any help would be appreciated.
LexBrett
05-19-15 12:02 PM
bkempf7
12
11-19-10 01:05 PM
ricandax
06-14-09 12:33 AM
Peter_95
08-07-08 10:25 PM
Quick Reply: 07 Domelight wire color and location?
