Purchased a 2008 LS460. DVD Changer and Aux-in issue
Old 06-22-14, 10:00 AM
mustafakha
mustafakha's Avatar
Default Purchased a 2008 LS460. DVD Changer and Aux-in issue
Hey guys,
I purchased my first LS about a week ago. It's a 2008 model with 62K miles.
I have an issue with the DVD changer and the aux in. I am unable to switch to the DVD changer using the Disc-aux button. When I press the Disc-aux button the internal HDD is activated which doesn't have any music on it. Once in this mode I can't switch the audio mode using the Mode button on the steering wheel. I have to press either FM or AM/SAT to get out of the HDD mode.
When I use the voice control and say DVD it says "Unable to read DVD."
Also, I can't load/eject discs to/from the changer.
Any help would be greatly appreciated. Radio is working fine.
Old 06-22-14, 01:18 PM
SBlexus
SBlexus's Avatar
Try plugging in an aux cable to see if anything shows on the navi screen.
Old 06-22-14, 06:02 PM
mustafakha
mustafakha's Avatar
I have tried with both aux cable connected and disconnected. Nothing seems to work.
Old 06-22-14, 10:27 PM
greg3852
greg3852's Avatar
Any warranty? Bring it back to the dealer
Old 06-23-14, 12:01 AM
mustafakha
mustafakha's Avatar
No warranty... the car was shipped from US to Dubai, UAE about two weeks ago.
the DVD Changer was functioning well till early last week and I didnt use it ever since. I purchased an aux cable on the weekend but couldnt switch to aux or DVD mode.
Old 06-23-14, 01:21 AM
Nospinzone
Nospinzone's Avatar
It sounds like you may have loaded a disc that somehow may have gotten stuck. Some discs are thick and that may be the problem. Try repeatedly to eject the discs. Otherwise a good stereo shop may be able to help you.
Old 06-23-14, 06:00 AM
mustafakha
mustafakha's Avatar
Nothing happens when I press the Eject or Load button. There should be an amber light which then converts to green but nothing!! No go.
Old 06-23-14, 06:27 AM
Nospinzone
Nospinzone's Avatar
Check the manual, maybe there's a dedicated fuse for the unit and it's blown.
Old 06-23-14, 10:20 AM
Dx3
Dx3's Avatar
Does your AUX work? I understand you mentioned it but I didn't know if you were referring to the Aux actually working or not.
I just went through this entire ordeal. Look for my thread on it.
Old 06-23-14, 10:37 AM
mustafakha
mustafakha's Avatar
No, the aux does not work. I can't even switch to aux in mode.
Old 06-23-14, 10:39 AM
mustafakha
mustafakha's Avatar
Checked the manual last night. There's are 4 different fuses for the radio(located in the driver and passenger side near the foot area). And it doesn't specify which fuse does what in the manual.
Old 06-23-14, 01:25 PM
Nospinzone
Nospinzone's Avatar
So did you check all 4 fuses?
Old 06-26-14, 11:40 AM
mustafakha
mustafakha's Avatar
Default Checked all fuses.
Checked all the fuses. ALL of them in the 4 locations. Under the hood, driver side under the steering wheel, passenger side under the glove box and in the trunk. All the fuses are working perfectly fine.
Old 06-26-14, 02:11 PM
Nospinzone
Nospinzone's Avatar
Hmmmm, I thought sure since you didn't see either a green or amber light that there must be a blown fuse. I'm still thinking there might be a stuck CD in the unit, but then I would think you would see the amber light when the unit tried to eject it.
I guess I revert back to taking it to a good car stereo shop.
Old 06-26-14, 11:16 PM
mustafakha
mustafakha's Avatar
Took these from the Diagnostic screen... does this help?
I noticed there is no "OK" next to the AUDIO OPTION AUX.
Attached Thumbnails Purchased a 2008 LS460. DVD Changer and Aux-in issue-photo-1.jpg   Purchased a 2008 LS460. DVD Changer and Aux-in issue-photo-2.jpg   Purchased a 2008 LS460. DVD Changer and Aux-in issue-photo-3.jpg
Quick Reply: Purchased a 2008 LS460. DVD Changer and Aux-in issue
