Oil Drain bolt snapped!
Old 03-06-14, 08:34 AM
lbintab
lbintab's Avatar
Default Oil Drain bolt snapped!
So we were changing my oil yesterday and when were tightening the drain bolt it snapped. It was a hollow bolt with, what I was told, a quick access port for some sort of diagnosis. I ended up just replacing it with a regular bolt. Anyone else have this happen to them and is it gonna be ok until the next oil change to keep that bolt?
Old 03-06-14, 08:42 AM
Lextrician
Lextrician's Avatar
So the drain bolt out of the oil pan correct and not the one for the filter.... should be fine I wouod check if any oil is leaking out n get a new one as soon as possible as that is temporary. Did you use the gasket as well??
Old 03-06-14, 02:15 PM
Nospinzone
Nospinzone's Avatar
A member here, robert1408, is pretty knowledgeable about this area (and I'm sure many others ). I would PM him and see what he thinks. Here is a link to a thread where he posted some info -
https://www.clublexus.com/forums/ls4...by-dealer.html
Old 03-07-14, 09:53 AM
jwin
jwin's Avatar
As long as it's not leaking you're fine until the next oil change when you can install the right bolt.
Old 03-07-14, 01:14 PM
randomwalk
randomwalk's Avatar
did you take the part that was broken out or is it sitting inside the oil pan?
Old 03-07-14, 06:16 PM
cerbum
cerbum's Avatar
If you were using a torque wrench to tighten the bolt, did it fail before you hit the proper torque for the bolt?
Stinks to have a bolt fail before it should.
Old 03-08-14, 04:19 AM
lbintab
lbintab's Avatar
I took the old one out. It failed just starting to tighten. Yeah it had a black cap over the quick access port that was built into the bolt. My buddy said it's a type of bolt that they can hook up a thing to measure oil pressure in diagnostics.
Old 03-08-14, 04:24 AM
randomwalk
randomwalk's Avatar
Just go to the dealer and get a replacement. Drain your oil in a clean container and reuse when replacing the bolt.
Old 03-08-14, 07:33 AM
roadfrog
roadfrog's Avatar
That's what I'd do. Run through a filter.
Old 03-08-14, 11:35 AM
vasy
vasy's Avatar
Default Fumoto valve
I've been using this valve on all of my cars for almost 30 years.
http://www.qwikvalve.com/?gclid=CKyP...FQFnOgodQSoASg
Old 04-18-14, 10:50 AM
Dx3
Dx3's Avatar
I use this - fantastic if you change your own oil
Old 04-18-14, 03:42 PM
RR601
RR601's Avatar
Is it easy to get to. Did you use ramps. I was debating if I was going to buy the low profile ramps for my LS.
Not too sure if I will change my own oil or not.
Old 04-20-14, 08:18 AM
roadfrog
roadfrog's Avatar
It's extremely easy to get to, but you do need ramps. I use a very old set (ie: VERY NON LOW PROFILE) of ramps. LOL. No problem though....I just place a piece of 2x6 lumber at the foot of the ramp so that my lip clears the starting incline of them.
Old 04-20-14, 12:35 PM
RR601
RR601's Avatar
Thanks,
But wonder if that would also work with my 2011 sport, since I think the front is a little lower.
Really don't want to spend 300.00 for a good set of low profile ramps if I am not even sure if I will use.
Old 04-20-14, 12:38 PM
RR601
RR601's Avatar
I have also used them for about 20 years on all my cars. Not sure if I will get one for my LS. Recently a mechanic told me that since they drain slower, a lot of guys will not let all the old dirty oil drain out like they would with a regular plug.
And not sure yet if I will do any of my own oil changes on this car.
GSLexTexas
01-17-17 09:20 PM
propcop
03-29-16 09:38 PM
propcop
08-05-15 03:00 AM
SISMO817
GS - 1st Gen (1993-1997)
03-27-07 02:13 PM
Norcalex
Performance & Maintenance
09-02-06 05:53 PM
Quick Reply: Oil Drain bolt snapped!
