07 Ls and 13 Ls suspension
Old 01-16-14, 02:20 PM
Tdvlexo
Tdvlexo's Avatar
Default 07 Ls and 13 Ls suspension
Does any one know if the 2007 Ls and the 2013 Ls suspension are the same or interchangeable?
Old 01-16-14, 04:35 PM
robert1408
robert1408's Avatar
I wondered the same thing. My mom just got a new '13 and I bought her '07. I've got a fairly good eye for under car stuff having done tires and alignments for 30 years or so. I've had a good look under both cars with good light.
I can see no design changes at all in the suspension itself, front or rear. The front subframe looks a little different where the steering rack attaches. Because the '13's a major mid-cycle refresh I'd guess many suspension parts have changed bushings and therefore different part numbers. Some subtle geometry changes are likely but not easily seen.
I read that Lexus claims 3000+ parts are new on the '13. I'd guess most of those involve the new dash and interior along with front and rear facias.
Old 01-17-14, 01:52 PM
lbintab
lbintab's Avatar
I suspect all the common parts that are known to fail have had a slight redesign but the geometry is all the same. Things like bushings and maybe something with the air struts but I have not confirmed any of this. Makes sense if they did because they've paid out a lot of dealers that have changed out these parts under warranty
Old 01-17-14, 02:19 PM
Tdvlexo
Tdvlexo's Avatar
Cause I was wondering if I could take the air struts from a 2013 and put it in a 2007 (wanting to know if it's a direct swap).
Old 01-17-14, 02:23 PM
lieup
lieup's Avatar
I was reading the 2008 & 2013 LS460(L) Production Information and notice that the Ground Clearance for 2008 with air suspension is 5.7 in. and 2013 F Sport with air suspension is 4.7. However, for the 2008 LS460 (L) RWD & AWD with standard coil suspension is 6.1 in. and 2013 LS460 (L) RWD & AWD with standard coil suspension is 5.1 in.
Old 01-17-14, 03:04 PM
lbintab
lbintab's Avatar
The struts will go in but the air management is not gonna swap into your car. You'll be better off doing an aftermarket setup.
Old 01-17-14, 05:19 PM
Tdvlexo
Tdvlexo's Avatar
My 07 have the air suspension, just wondering if the 2013 will be direct bolt on(just the air shocks).
DShiekhi
02-09-16 05:08 PM
NobleSpine
12-20-12 01:58 AM
damon
10-21-05 07:57 PM
TRDFantasy
07-09-05 11:04 AM
Quick Reply: 07 Ls and 13 Ls suspension
