Need advice about replacign Brake Pads for my 2008 LS 600hl
Old 04-15-13, 01:55 PM
lexus600hl
lexus600hl's Avatar
Default Need advice about replacign Brake Pads for my 2008 LS 600hl
I have two 2008 LS 600HL nieman marcus edition cars (Nieman Marcus wheels are different. Hopefully brakes are not different?)
One of them needs brakes. Dealer quoted $800 to resurface the rotors and replace pads.
Dealer said that the rotors need to be resurfaced.
I am seeking advice to replace the pads. One of my employees has replaced brake pads on cars but never a Lexus. I will ask him to replace the pads. I won't even have the rotors resurfaced.
1. What do I need to buy in terms of parts?
2. I would prefer to buy from Sewell Lexus. They give great discounts. But I saw Akebono. Would they be better? I don't like squealing.. I have no squeal right now.
Sewell Lexus has pads for about $55 per pad kit but they have two options: textar and Mark advics. Is one preferrable to the other?
Also, for the front, swell has : 04945 0494550110
SHIM KIT, ANTI SQUEAL, FRONT
Whats this shim kit? I have not had a brake squeal problem. I don't know whether my car has the shims or not. Do I need to order them?
What should I order along with rear brake pads?
I just want to order a kit. Can someone knowledgeable, advise me on this?
Thanks.
Old 04-15-13, 05:21 PM
BarrettF77
BarrettF77's Avatar
I can't advise you on most of the stuff, but what I can say is that you want to find out if the parking brake is electric or not. If it is, you might need a computer to fully disengage the rear parking brake mechanism to do any brake work back there.
Otherwise, it can certainly be a DIY type job. I'm sure others will chime in on that.
Old 04-15-13, 05:34 PM
Lextrician
Lextrician's Avatar
parking brake pads are seperate from the rear. the parking brake is like a drum where your rear will be regular pads. nothing too hard
mikek753
06-27-19 10:33 AM
lexrally
RX - 1st Gen (1999-2003)
13
07-15-15 01:18 PM
JFNash
03-05-10 02:25 PM
Skyhigh82
14
07-23-09 10:38 AM
nysupraman
Wheels, Tires & Brakes Forum
04-29-04 01:15 AM
Quick Reply: Need advice about replacign Brake Pads for my 2008 LS 600hl
