Wind noise
Old 09-02-12, 05:48 AM
waynedog
waynedog's Avatar
Default Wind noise
I have a 2007 LS I purchased a few months ago. Wind noise from windows is very loud. I applied the jmcraney fix this week - did it exactly as the directions say. Made no difference in wind noise - still get a bunch of wind noise through the windows. My LS has 70k miles so it is out of warranty. Any other suggestions as to what I should do?
Thanks
Old 09-02-12, 07:04 AM
Valley101
Valley101's Avatar
Default Wind noise
Did you take the car out on the highway for a thorough test drive before driving it! If you did and no wind noise was present then maybe the seals around the door are the problem or slim possibility doors are out of adjustment.
Old 09-02-12, 07:24 AM
waynedog
waynedog's Avatar
The car had the wind noise when I test drove it. I assumed it could be fixed with the mcraney solution. It did not work.
Old 09-02-12, 12:09 PM
Craig B
Craig B's Avatar
I don't know if your car had the windows replaced? Mine had the front windows replaced with double glass like what's on the LS 600.
Old 09-02-12, 05:33 PM
Luxofreak
Luxofreak's Avatar
Same here, my windows were replaced by double laminated ones under warranty and I have absolutely no wind noise. I didn't need the mcraney solution. My car is tomb quiet.
Old 09-02-12, 07:28 PM
Ys88q7
Ys88q7's Avatar
I hear just a tad bit of wind and I also have the double laminated windows installed.
Old 09-03-12, 09:18 AM
FLYCT
FLYCT's Avatar
I bought an 09 CPO LS last month. How do you tell if windows are upgraded to the double laminated type?
Old 09-03-12, 09:51 AM
nsaldanh
nsaldanh's Avatar
Look on the front window glass. If you see the word lamisafe on it you have the laminated glass. If you see temperlite then it's single pane glass.
Old 09-03-12, 09:54 AM
FLYCT
FLYCT's Avatar
Mine say temperlite.
What is required to get windows replaced to upgrade?
Car is still under factory warranty.
Old 09-03-12, 10:01 AM
jmcraney
jmcraney's Avatar
Here is a link to a post from several years back that explains about the window retrofit: https://www.clublexus.com/forums/4137877-post443.html
Old 09-06-12, 10:39 PM
FLYCT
FLYCT's Avatar
OOPS. I misspoke. My rear windows say temperlite and front windows say Lamisafe.
Jerry
Old 09-07-12, 11:14 AM
ehaze
ehaze's Avatar
was at my local dealer last month (08/2012), my SA said there still isn't a fix and extended warranties don't apply to wind noise.
lexus dropping the ball again.
new GS, same issue.
https://www.clublexus.com/forums/gs-...-resolved.html
Old 09-08-12, 12:31 AM
I8ABMR
I8ABMR's Avatar
I still get some noise but its much much better than before
Old 09-08-12, 04:08 AM
nsaldanh
nsaldanh's Avatar
Jerry
Time for Jim McRaney's fix. He has a thread with very good instructions.
Old 09-08-12, 03:54 PM
waynedog
waynedog's Avatar
Already did the McRaney fix - did not help.
Quick Reply: Wind noise
