Engine issues
Old 02-24-12, 04:08 PM
Grisik
Grisik's Avatar
Thanks. Called today to check on the progress. The advisor said they got the parts yesterday and it would be mid next week before it was done. Sounds like alot of time to put it back together. The question I have now is will they replace the spark plugs or use the original ones? I'm hoping they use new ones but the old ones were out.
Old 02-27-12, 04:47 PM
Grisik
Grisik's Avatar
Just got the car back. Seems to be running good. They replaced both heads and everything attached to them. New valves , springs, spark plugs ect. See how runs over the next few days.
Old 02-27-12, 06:10 PM
Mikey100
Mikey100's Avatar
I got a good feeling you're gonna finally enjoy your ride, with no more worries nor problems.
Congrats - Glad it worked out so well for you.
Mikey Lulejian - Lake Oconee, GA
Old 02-27-12, 07:37 PM
Lextrician
Lextrician's Avatar
that's good to know lexus took care of ya. enjoy..
Old 05-03-12, 05:46 PM
Grisik
Grisik's Avatar
##Update##. With 72503 miles on the car, or 4400 miles since the heads were replaced, the car runs about the same as when this all started. The low oil light came on this evening. The hesitation seems to be getting worse over the past 1000 miles. Could another set of heads go bad in 4400 miles? I thought this problem has been fixed? Is there a lemon law with 72500 miles?
Old 05-03-12, 06:16 PM
Lextrician
Lextrician's Avatar
I am not sure but I know there should be a warranty for there work all you can do is complain and make them take it back because I wouldn't be satisfied.... at all.
Old 05-03-12, 07:14 PM
CJITTY
CJITTY's Avatar
What in theee hell???
Old 05-07-12, 03:19 PM
Grisik
Grisik's Avatar
Took the car in today to Lexus Rivercenter. Could not reproduce the hesitation. They checked it over and said everything is fine. I ended up burning 1.5 qts of oil in 4600 miles. They said that was well within the acceplable range. Told them it never burned a drop until the VSR then it all went to hell. They then made me a copy of the manual were it says 1.1 qt in 600 miles was acceptable.
Old 05-07-12, 03:40 PM
Nospinzone
Nospinzone's Avatar
Considering that the heads were replaced, the oil consumption is troubling. Presumably you should have cylinders milled to exact specs. If it was done properly, your engine should propel the car faster than a comparable LS, use less oil, but also be less fuel efficient.
I would question the competency of the job, but you may have some other problem with that engine.
Old 05-08-12, 09:46 AM
edarte
edarte's Avatar
Location: Vancouver Island, BC -ex Illinois &Toronto, ON
This hesitation that you feel; could it just be the hesitation that AWD owners have noticed, going uphill, under light acceleration, around 40-50 MPH?
Old 05-08-12, 03:42 PM
Grisik
Grisik's Avatar
Yes it is under light acceleration around 40-50 mph. It is not an all wheel drive.
Old 08-01-12, 06:54 PM
Grisik
Grisik's Avatar
Default Hesitation
Im starting to lose confidence in this car. Today coming up a hill the car started cutting out and would not go. Pressed down on the accelerator and it would not go. This is the same problem I've been having but its getting worse. Of course it can't be duplicated at the dealer. They tell me that can't find anything wrong. I need some help.
Old 08-01-12, 07:28 PM
SBlexus
SBlexus's Avatar
Hi Grisik I was reading some of your post, and my question is what type of fuel are you running in your car?
Old 08-02-12, 05:35 AM
Grisik
Grisik's Avatar
Shell or BP 93
Old 08-02-12, 07:48 AM
SBlexus
SBlexus's Avatar
Shell or BP 93
Ok because I have a pick that I drive to work it's a 08 f150 when I put different octane in it the truck lose power and it has the V8. Maybe u gotta fuel problem check the fuel filter make sure you don't have any type of restriction and your getting enough fuel pressure.
Quick Reply: Engine issues
