Is there an aftermarket trim piece w/exposed driver's door keyhole?
Old 10-25-11, 06:49 PM
N4TheChase
N4TheChase's Avatar
Default Is there an aftermarket trim piece w/exposed driver's door keyhole?
It is to replace the piece that covers the keyhole, which comes off. If so, does anyone know where I may get one?
Many thanks!
Old 10-25-11, 08:57 PM
brianlin87
Resident JDM Snob
brianlin87's Avatar
I think this is maybe what you're asking for?
If that's what you're referring to, then yes, Garson makes that one; however,
If you want something that replaces the entire door handle altogether,
Grazio & Co. makes this one:
Old 06-12-16, 11:34 PM
N4TheChase
N4TheChase's Avatar
I went to a Lexus dealer and got a driver's door key cover. It's a plastic piece, and I believe it is like $14. I then went to a body shop, and they cut a precise hole in the cover (just large enough for the key to go through). Now, I can unlock and lock my car manually without having to remove the key cover (e.g. lock the car with the engine running).
ginessgold
07-13-09 03:10 PM
jmr32
02-04-07 09:51 AM
Quick Reply: Is there an aftermarket trim piece w/exposed driver's door keyhole?
