Acceleration Problems after Dealer Oil Change
Old 03-13-13, 05:31 PM
Fhobbs
Fhobbs's Avatar
I would be interested to hear the results. I had mine done recently and it took awhile, about 4 takes worth of gas driving, to get back to normal.
Old 03-13-13, 07:54 PM
Valley101
Valley101's Avatar
Default Engine hesitation after oil change
I have owned three Lexus vehicles bought new. I have never had any problems period. Not saying I won't have some issue in the future, but what your describing is weird.
Old 03-14-13, 07:54 AM
wchain
wchain's Avatar
Since few people have updated this thread, I figured I'd keep it updated.
My service advisor just called and told me that they did a software re-flash and it "runs like it should".
He says they've seen about half dozen LS460s do this in the last 3 or 4 years, no explanation, car comes in for a routine oil change and then leaves with driveability issues. I'm going at lunch to pick it up.
DrQuality (08-05-21)
Old 03-14-13, 07:06 PM
wchain
wchain's Avatar
Update 2:
Picked car up, drives 10% better but still screwed up. Paperwork says they updated the Transmission software and reset the memory.
The car runs smooth but when you mash the gas, it runs like its got half the horsepower.
Will be taking the car back again.
Old 03-15-13, 09:28 AM
gs400jon
gs400jon's Avatar
Originally Posted by wchain
Update 2:
Seems to me your dealer techs don't know how to properly reset after servicing. I have never had an after service problem. The only problem I had with slower acceleration was after the valve spring replacement on my previous LS460. My service advisor said by the time I drove 100 miles, the ECU will learn how I drive. That's exactly what happened.
Old 03-18-13, 12:22 PM
pearlLS460
pearlLS460's Avatar
Default Update
This is an update for my post several months ago.......The dealer reflashed the cars computer to the latest software version as the service bulletin mentioned inthis post suggests. The car operates normally now. I will be changing my oil again in the next few days. We will see what happens!
Old 03-18-13, 12:57 PM
wchain
wchain's Avatar
Update to my post, didn't drive the LS all weekend, drove it today to the office to drop it off at the dealer at lunch, and halfway to the office, it started running better, and at lunch time, it runs 95% back to its "old glory".
Go figure. My guess is that the Adaptive transmission needed to re-learn?
Old 03-18-13, 01:19 PM
randomwalk
randomwalk's Avatar
This is what I meant when I told you it's "intermittent". You never know when it will come and when it'll go. Every time it happened, I scheduled for an appointment and when that appointment time came, the problem mysteriously "solved" by itself. The dealer thinks I'm crazy...Now I just keep on driving and hopefully it just go away ...which it does but it sucks when it's there. It helps if you disconnect the battery for 5 mins or so and plug it back in...although you may loose your radio settings and such.
Old 03-25-13, 01:03 PM
wchain
wchain's Avatar
Spoke too soon, car is acting up again.
Old 03-25-13, 01:33 PM
silver305
silver305's Avatar
i believe it is time to let go of your car and trade it in.. even under warranty, i would be beyond fed up with this entire nightmare you are having. Too much to deal with as if work and paying bills isnt stressing enough..
Old 03-25-13, 06:42 PM
caha14
caha14's Avatar
https://www.clublexus.com/forums/7783850-post6.html
This is the latest version of the hesitation TSIB. Based on what it says and with conversations with people at the dealership, I wouldn't be surprised if your car needs cylinder heads, especially since it is a 2007.
Your dealership's Diagnostic Specialist would need to drive it with the Techstream computer connected to record knock correct values and other parameters. If the values are outside the desired range, it can mean automatic replacement. That Techstream computer is a thing of beauty, by the way, but that's a different story.
Apparently, there is an issue with the valve guides, whereby they can make a noise that the knock sensors interpret as engine knock, and spark timing is retarded as a result. At the extreme, if this happens excessively, the car will not go very fast (or far).
For my own car, the software update thankfully did the trick (already two years ago).
Old 03-25-13, 08:00 PM
wchain
wchain's Avatar
I was telling someone else that it feels like the Engine computer was pulling timing, which is my suspicion. I will show this TSIB on Wednesday when I go in. Its certainly frustrating, but I'm not going to trade in a car when it can be fixed.
Old 03-25-13, 08:38 PM
silver305
silver305's Avatar
when it can be fixed? it is OBVIOUSLY not the case at this point. I am just the type of person that if a car gives me massive headaches, i cut it loose. I dont have the time/money to be making payments on a car that i am hardly driving because it is in and out of the dealership. Right now, mine does not have warranty and i have the typical front "knock" that happens due to either the brake actuator or control arms. If this gets louder, then i will find a brake actuator somewhere for a decent price and have my mechanic swap it out. If that doesn't fix the problem then i will look into the control arms. If those get replaced and i still hear the annoying sound, i will pull the trigger and cut it loose they way the cut Michael Vicks for what he did. Cars are cars and i dont have the type of personality that likes to complicate life over a vehicle who is acting up all the time.
Old 03-25-13, 08:58 PM
wchain
wchain's Avatar
Didn't you just buy your car a month ago?
Most people that can afford to buy a LS460 can afford to have them repaired. With the issues you sound like you're having, maybe its better to pay an indy or a dealer to diagnose the issue before throwing money on an actuator that may or may not fix the problem.
I am going to give my dealer/Lexus the benefit of the doubt here and let them have the chance to fix it.
Its under 6/70 Powertrain and I have an extended warranty that is good till 2016 or 100K, so its covered.
Old 03-26-13, 02:20 AM
redoctane
redoctane's Avatar
Please keep us tuned with the results it is interesting to find out what was the problem.
Quick Reply: Acceleration Problems after Dealer Oil Change
