Uneven Drop w/ DataSystem Controller
Old 07-17-11, 06:34 PM
telmz1
telmz1's Avatar
Default Uneven Drop w/ DataSystem Controller
So I installed this DataSystem Controller & Harness on my 09 460L and started messing with the settings since I couldn't read the Japanese operations manual.
I figured out the Memory setting based on the various levels of height but I noticed that not all 4 corners are the same height. The driver side front is about 1 inch higher than the rest. I think I screwed this up by adjusting the levels on my driveway instead of a level surface like the garage.
Can someone please help me fix this? Is there away to reset this thing?
Old 07-17-11, 09:20 PM
Nat
Nat's Avatar
Put it on even ground and raise it all the way up..then drop it to your desire setting. My driver front corner is about 1/4 higher then then passenger. I notice that it drops a little more after driving.
Old 07-17-11, 09:38 PM
telmz1
telmz1's Avatar
Raise it to like B or C? Is Normal Select a setting? Ie Normal/Stock height?
Old 07-17-11, 10:23 PM
cheez80
cheez80's Avatar
you can also adjust ride height for the 2 sides of the front axle independently, i think, to compensate for issues like that. not exactly sure how -- i don't have the controller in front of me at the moment
Old 07-17-11, 10:56 PM
telmz1
telmz1's Avatar
I think i figured it out after playing with the controller a little more. I can't get the back even though. It looks like you can only put different levels for the front. The rears have to be the same...unless someone can show me how.
Old 07-17-11, 11:22 PM
rominl
exclusive matchup
rominl's Avatar
rear 2 can only go together, only independent adjustment up front
and the uneven heights are normal, tell lexus that. from factory their cars have different gap on all corners to begin with
Old 07-18-11, 07:13 AM
305Busa
305Busa's Avatar
I corrected that uneven height with the controller. Like rominl mentioned, the rear raises and lowers together and the front is independent.
Old 07-18-11, 02:15 PM
telmz1
telmz1's Avatar
Thanks everyone - your help has been great!
Streetcar1
05-26-17 11:07 PM
SoCal_450h
Suspension
12
05-16-10 08:45 AM
sojah
04-22-09 04:32 PM
Scythe
Suspension and Brakes
25
04-04-08 11:07 PM
Flipsonic
11-29-06 07:23 AM
Quick Reply: Uneven Drop w/ DataSystem Controller
