Little Smoke When Starting
Old 05-18-11, 06:08 AM
Nash
Nash's Avatar
Default Little Smoke When Starting
This may not be a big issue but i recently got an 07 LS and noticed when i start it or sit at a light, it tends to have some smoke from the exhaust even when its hot outside. The car runs and drives fine but i was curious if anybody else has seen this from there cars or has had this issue?
Old 05-18-11, 06:44 AM
cmasten
cmasten's Avatar
I have an 07 as well (72,000 miles) and only had this when I jumped on it. The VSR has completely taken care of the issue. Did you have your VSR performed as of yet? not a fix per se, but curious.
Old 05-18-11, 09:50 AM
Nash
Nash's Avatar
I just bought the car and im not sure. I will have to check with my lexus rep and find out.
Old 05-18-11, 12:46 PM
Silverpaws
Silverpaws's Avatar
What color is the smoke and does it do it after the engine is fully warm? Usually, when there is smoke under the circumstances you described, it will be black, white, or blue. Maybe one of the technician members will provide some input.
Old 05-18-11, 02:11 PM
Nospinzone
Nospinzone's Avatar
If it's white smoke, it's water vapor. If it's black smoke, it's oil......and that's not good.
Old 05-18-11, 09:46 PM
I8ABMR
I8ABMR's Avatar
Is it cold when it does it? Do you smell anything nasty when you back up? Most likely it totally fine but ask the dealer at your next service
Old 05-19-11, 04:59 AM
Nash
Nash's Avatar
Yea ill just have to get it checked out once i get the vsr done on it, if it hasen't been done yet.
Old 05-19-11, 06:20 AM
tenspeed
tenspeed's Avatar
Typically, blue/black smoke at start up is oil leaking pass the valve guides. Sort of normal for an older engine.
Old 05-19-11, 08:05 AM
Craig B
Craig B's Avatar
Blue smoke is oil, black smoke is carbon. He might just see condensation, which is normal...
Old 05-19-11, 09:20 AM
Silverpaws
Silverpaws's Avatar
Agreed and here is some smoke being caused solely by aggressive driving habits
bondavi
01-17-13 12:26 AM
Sup2jzgte
Performance & Maintenance
14
10-29-10 08:41 PM
Sirius2ten
18
02-07-08 12:51 PM
oblivionis
04-06-07 08:14 PM
Quick Reply: Little Smoke When Starting
