Prestigious lowering help
Old 04-14-11, 01:59 PM
crza81
crza81's Avatar
Default Prestigious lowering help
I installed the prestigious lowering module on my 08 ls460L.
Has anyone had issue with leveling. I had an issue twice so far where the car from the L setting will raise only the drivers side and passengers side will only go up slightly. Also if someone could give me some info on what functions the module can do.
I am bothered by this controller and am wondering if anyone has removed all of the factory controlls and ran an aftermarket tank , compressors and controller on the stock bags and lines? Is it possible......
Thanks in advance!
Old 04-14-11, 02:21 PM
cheez80
cheez80's Avatar
Thanks in advance!
of course it's possible -- the vip auto salon ls600hl is running UAS bags.
Old 04-14-11, 02:26 PM
crza81
crza81's Avatar
I was wondering if the stock bags could be used with aftermarket air control switch box , tank and compressor.
These air controller glitches are gonna stress me out....
Has anyone else had issues or glitches with the prestigious controller?
Old 04-14-11, 02:35 PM
Nat
Nat's Avatar
Make sure that the floor is level when using the controller. I notice that this will help. No matter what you do, even with after market bags, it will not be even all the way around. It is more obvious because the car is lower. You can measure the car at stock height and it will still not be even. I also notice that after it reaches the setting, when driving on "comfort" it will settle and go down a little lower.
Old 04-14-11, 03:58 PM
cheez80
cheez80's Avatar
ah, not sure about that. youzealand did make a setup for ucf30 that used the stock bag, compressor, etc. with an aftermarket, ride height adjustable aragosta shock. price was like $6k+ haha
thatLSdude
11-14-14 07:54 AM
v_eye_pee
12-13-11 03:51 PM
cheez80
01-20-11 06:28 AM
J R
VIP Style
10-12-07 04:28 PM
Quick Reply: Prestigious lowering help
