Nike Light Fuse Location?
Old 03-12-11, 09:42 AM
StylinGS300
StylinGS300's Avatar
Default Nike Light Fuse Location?
Hi Everyone, I just tried to swap out my nike lights bulbs with the led bulbs and it doesn't work. I put the original bulbs back in and it still doesn't work. I might have blown the fuse. I tried to locate the fuse but I can't find it. Does anyone know where the nike light fuse is located? Any help is appreciated.
Old 03-12-11, 07:54 PM
cmasten
cmasten's Avatar
The LEDs will usually need to go in one way, as they are diodes in nature and if they dont work, flip them. If your original bulbs are now not working you can look in the back of the user manual and that has the best descriptions of the various fuses located in each of the 5 (in total) fuse boxes. There are two under the hood, one under each side of the dash and one in the trunk. My guess would be that each bulb has a fuse under the dash on its respective side, but you would need to look through the manual to validate that.
Old 10-12-11, 12:50 AM
gcam77
gcam77's Avatar
Were you able to locate the fuse for the nike light?
brianskiim
05-28-15 11:00 AM
642jdub
02-21-15 12:52 AM
natemm
Lighting
12-04-04 08:31 PM
2JZGE
Lighting
01-31-03 10:32 AM
Quick Reply: Nike Light Fuse Location?
