Do I need to replace the rotors?
I'm disappointed in Lexus brake system. When you need it the most, it won't work for you as it is supposed to. It just sucks.
I'm replacing the OEM brake pads to Axiis ceramic pads. Do I need to replace the rotors as well?
Would you recommend slotted rotors that supposedly dissipate heat?
Thanks.
Thanks.
Thanks.
Thanks.
p.s. complain to dealer if it breaks not as expected...having ceramic brakes on LS will make braking sound much louder...
Could you be more specific. It doesn't sound like the pads are the problem. You have to do some pretty hard and pretty frequent braking (as in racing) to realize the full value of ceramic pads.
Of course, one value is a lot less, and easier to clean, brake dust.
Ceramic pads are prolly the lastest standard for any daily drive purpose vehicles, and it should perform better in any way when comparing with the traditional kind (semi-metalic). It should reduce (to none) the noise and less brake dust according to its standard AFAIK.
I guess you had bad luck with your previous brake service, or maybe the service brake performed without resurface the discs. Tire Rack has a few highend ceramic pads and I recommend pads by Akebono.
from my 2cents,
from my 2cents,
Almost forgot I need to stay with the original topic.
You prolly don't need to replace it yet but take it to any local repair facility and have them to check out if it holds at minimum thickness after resurfacing.
Slotted or drilled rotors? It is not a performance vehicle so I don't recommend it unless you just want to get better look with the "upgrade"
In general, slotted rotor performs better than the drilled ones because slotted ones have more gripping surface than the drilled ones. Use o/e rotors for its quality, or you can use highend ones like Brembo if you have extra love and money for your car.
I am sure the fleabay has some fancy looking ones but who knows how good they are...
Thanks.
Thanks.
What caused the squealing? Was it because of the ceramic material itself or something else in the braking system? The reason I'm asking is that I read that ceramic pads are quieter than the semi-metallic ones. Plus, they provide firmer braking (this is my biggest reason to switch to ceramic) and less dusty (not really a big concern for me as I get my car cleaned every day).
from my 2cents,
from my 2cents,
On my GS400 I had more brake dust with my ceramic then my semi-metallic. The noise came from the buildup of the dust. Everytime I got my car washed it went away then came back after about a day of driving.
ceramic brakes usually have a less bite/performance than semi-metallic pads..
their pros are that they dust less, last longer, and are usually more quiet..
melymel96, your squealing might have been due to lack of lube in the shims and the brackets...
if you want better braking performance, I recommend better/sticker/summer tires over oem tires and harsher pads.. those AXXIS might not do the job if they are ceramics.. i would recommend finding semi-metallics..... I would try out the tires first.
