Wiring for Radar Detector
My LS has all those black dots in the glass around the mirror. These are for sunshading around the mirror the regular visor shades don't cover.
I've heard the V-1 doesn't get the usual range compared to the usual window glass mounting. Have you had a chance to compare them?
Whit
Whit
Whit
When I wired my V1 power I found a wire on a plug up behind the overhead console leaving me with just a two foot run to the windshield location.
Seems like there was a 10 or 12 conductor plug and I found one conductor to go hot with ignition switch on.
DON'T use any metal you find to be a ground return. I did that and the V1 was intermittent. Further inspection revealed the metal not to be tack welded to the overhead roof as I had assumed. It was affixed with an adhesive...a very non-conductive adhesive, so I found another wire on that same plug that was a solid ground and I tapped onto that.
I remember writing up the procedure on this forum a few years ago, but can't find it on here now...sorry.
