DIY / Info thread for LS460/LS460L/LS600hL
Old 04-07-11, 04:44 AM
Tee
Tee's Avatar
How to install corner (Nike light) LED's.
https://www.clublexus.com/forums/6170933-post16.html
https://www.clublexus.com/forums/6170950-post17.html
The thread: https://www.clublexus.com/forums/ls4...bulb-swap.html
How to install reverse light LED's
https://www.clublexus.com/forums/6290412-post124.html
Tee is offline
Old 04-12-11, 04:46 AM
Tee
Tee's Avatar
How to clean exhaust tips
https://www.clublexus.com/forums/5931364-post10.html
The thread: https://www.clublexus.com/forums/ls4...aust-tips.html
Tee is offline
diamente (12-01-22)
Old 06-21-11, 04:53 PM
vraa
CL Folding Team Starter
vraa's Avatar
Originally Posted by lexusnutt
There seems to be a lot of references to this website for ls460 TSIB's
Pretty complete listing. I may one day copy all of the files and post them to www.scribd.com for permanence.
http://www.lambros.net/2007LS460L/tsib/
this is a INCREdible site thanks
vraa is offline
Old 07-14-11, 02:42 PM
kbinfl
kbinfl's Avatar
Question Engine Air Filter
Has anyone replaced their air filter DIY? Where does it live under the plastic covers? I assume it's not that difficult.
kbinfl is offline
Old 07-14-11, 06:35 PM
kbinfl
kbinfl's Avatar
Never mind, I figured it out myself. Didn't realize there were two air filters under there. Luckily I ordered 2. Really simple to do. Just remove V8 cover by lifting gently and they're both right there on top of the engine.
kbinfl is offline
Old 09-20-11, 07:26 PM
vraa
vraa's Avatar
This needs to be added
www.lexus.com/pdf/service/Sedans.pdf
Maint Schedule
vraa is offline
Old 09-20-11, 07:38 PM
vraa
vraa's Avatar
Any update on the lambros site? It says Updated Jan 28, 2009
vraa is offline
Old 10-11-12, 10:29 PM
CJITTY
CJITTY's Avatar
Here is my video on how to listen to two different sources at the same time on 2007-2009 Rear Seat Entertainment equipped LS460/LS600 models
CJITTY is offline
Old 10-12-12, 07:37 PM
SBlexus
SBlexus's Avatar
http://www.youtube.com/watch?v=ZTU28...d&noredirect=1
Great video
SBlexus is offline
Old 10-26-12, 04:25 PM
RandyV
RandyV's Avatar
Originally Posted by walking50
hello ...
can anyone provide instructions on how to replace the HID bulbs on the LS 460 .... seems pretty cumbersome to get through to the bulb cover..
thanks
Anyone? Anyone? Bueller? Anyone?
RandyV is offline
Old 10-26-12, 05:25 PM
Lextrician
Lextrician's Avatar
depending on which side you have to turn your wheels away from you or just take the wheel off so that you can pull away the plastic fender liner which requires removing the push pins move that back and your bulb access is right there..
Lextrician is offline
Old 10-28-12, 12:26 PM
RandyV
RandyV's Avatar
Sounds easy enough.
So no detailed write-up out there?
RandyV is offline
Old 11-30-12, 03:54 AM
farming
farming's Avatar
Originally Posted by RandyV
Sounds easy enough.
There's a write-up by CJitty on these forums. Google search for it within the CL site.. It's actually really easy according to him. I'll have to see for myself when I get my car.lol
farming is offline
Old 12-11-12, 03:58 AM
philipjdm
philipjdm's Avatar
i know this is the sticky thread, i was wondering have anyone done a the fog light mod, like the 2nd gen GS?
philipjdm is offline
Old 12-18-12, 08:57 AM
Tee
Tee's Avatar
Default HID/Low beam Headlamp Replacement Instructions
NOTE: All HID bulbs should be replaced in pairs to ensure equal bulb life and even light ouput.
You have to remove the wheels and then the fender lining to replace the bulbs. This is how the service manual shows replacing the bulbs, use a flat head to remove the liner tabs. You can do it, might take you 20 mins ea. or less. But you can turn the wheel pull the liner back and reach in to replace them if you have done this before as well.
Tee is offline
Quick Reply: DIY / Info thread for LS460/LS460L/LS600hL
