Go Back   Club Lexus Forums > Lexus Model Forums > LS Models > LS460, LS460L and LS600h
Sign in using an external account
Register Forgot Password?
LS460 Wind Noise Fix (continued discussion)
Thread Tools Search this Thread Display Modes
Old 03-28-14, 10:40 AM   #811
Rhaines
Trader Score: (0)
Quote:
Originally Posted by RandyV View Post
The best and easiest fix is to push the window down button for a micro-second.
This unloads the window bowing at full up, and significantly reduces wind noise.
Give it a try, you'll see.
Randy- I have a LS460L and would like to chat with you. I live in Coronado.
Robbie
619-997-7722
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Rhaines is offline   Reply With Quote
Old 03-29-14, 08:32 AM   #812
Arvid
Trader Score: (0)
Arvid's Avatar
Default Maybe this is already well known by the members...but..
...Lexus have a few fixes that they have come out with for the 2007/8 Ls 460.
http://www.lambros.net/2007LS460L/tsib/
See there at lambros.net under Noise, Vibration, and Harshness .. could maybe be of help...
Regards
Arvid
Arvid is offline   Reply With Quote
Old 03-29-14, 09:14 AM   #813
sktn77a
Trader Score: (1)
sktn77a's Avatar
Unfortunately, I don't think any 2007/2007 LS460s are still under the original factory warranty, so none of these fixes would be covered.
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2007 Lexus LS460
2005 Toyota Prius
1999 Lexus RX300 AWD
sktn77a is offline   Reply With Quote
Old 03-29-14, 09:31 AM   #814
Arvid
Trader Score: (0)
Arvid's Avatar
Quote:
If they would still be covered..it would be amazing ...but for a handy man ( or rather..in these days...a handy person) it could be a DIY
Regards
Arvid
Old 03-29-14, 10:23 AM   #815
jmcraney
Trader Score: (0)
jmcraney's Avatar
None of the Lexus TSIBs in the Lambros list have been effective in reducing wind noise except for the part that replaces the glass in the front doors. Most wind-noise-suffers have found relief with the DIY fix that is here: http://www.clublexus.com/forums/ls46...noise-fix.html
jmcraney is offline   Reply With Quote
Old 03-29-14, 10:43 AM   #816
sktn77a
Trader Score: (1)
sktn77a's Avatar
Quote:
This is the laminated glass front window replacement?
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2007 Lexus LS460
2005 Toyota Prius
Old 03-29-14, 12:05 PM   #817
jmcraney
Trader Score: (0)
jmcraney's Avatar
Yes, part of this TSIB (http://www.lambros.net/LexusTechInfo...L-NV009-07.pdf) retrofits the windows in the front doors with laminated glass. There are no indications that any of the elements of the TSIB were beneficial other than the glass replacement. The glass replacement only applies to all 2007 LS460s (swb only) and a few of the early '08 LS460s. Many of the '07 LS460s were not regarded to have the wind noise problem even though they came equipped with the single ply glass. I am confident that the window retrofit is beneficial but anyone having a problem should do the DIY trim repair first and then decide if they are satisfied.
Old 03-29-14, 01:45 PM   #818
Fhobbs
Trader Score: (0)
What I found with the window replacement on mine was the reduction of noise from traffic passing on either side. The DIY Trim fix has been the most successful for wind noise. I still find myself bumping the window down slightly for optimum results.
Fhobbs is offline   Reply With Quote
Old 03-29-14, 03:13 PM   #819
sktn77a
Trader Score: (1)
sktn77a's Avatar
The glass replacement only applies to all 2007 LS460s (swb only) and a few of the early '08 LS460s. I am confident that the window retrofit is beneficial but anyone having a problem should do the DIY trim repair first and then decide if they are satisfied.
Unfortunately, for those of us that did not get the glass swapped out, I fear it would be prohibitively expensive now.
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2007 Lexus LS460
2005 Toyota Prius
Old 04-03-14, 02:00 PM   #820
greg3852
Trader Score: (0)
greg3852's Avatar
Found a little something today at the dealership that I wasn't aware of. If you look at the 2007 photo, you can see the fender stops at the door. But if you look at the 2014 photo you can see they changed the way the fender covers the door opening. It is clearly bumped out in the areas I crudely pointed out. I can't see how they would do this as a design feature because who would actually notice this? Anyway not sure if its been discussed before, thought I'd add it if it hadn't. Sorry the pictures aren't the best.
2007
2014
greg3852 is offline   Reply With Quote
Old 04-03-14, 03:40 PM   #821
Fhobbs
Trader Score: (0)
That is interesting. I am going to look at the door seal at that location and see if there is anything there that would lead one to believe it could contribute to wind or road noise.
Old 04-03-14, 04:05 PM   #822
sktn77a
Trader Score: (1)
sktn77a's Avatar
Quote:
Or maybe the quality control over panel fit is sliding?
__________________
Keith
2010 Toyota Prius
2008 Lexus IS250
2007 Lexus LS460
2005 Toyota Prius
Old 09-30-14, 10:52 AM   #823
SUL4589
Trader Score: (0)
Default LS460 Wind Noies Revisited
I have owned a 2006 LS430 for a number of years and logged 197,000 miles with no issues.
So I purchased a low mileage 2008 LS460. The one thing I did notice is quite a bit of wind noise and visited this forum. I applied all of the fixes and did find I had the laminated glass on my car. But still had more noise than my 2006. So I started trying things and have now come up with a fix that greatly reduces the noise I had. What I found is the chrome strip on the outside bottom of the front windows has a gap under it. There is a rubber gasket there but it does not contact the main part of the door in fact it was easy to slip a putty knife under it. So I ran a piece of blue 3m tape along the strip and took the car for a ride. And the wind noise had gone down quite a bit. Removed the tape and put a sealer under the trim and things are much improved. Had to post this because of all of the great advice I find here.
Hope this helps someone out there chasing the same thing I was
SUL4589 is offline   Reply With Quote
Old 09-30-14, 03:59 PM   #824
GXAlan
Trader Score: (0)
Do you mind taking a picture of your fix?
GXAlan is offline   Reply With Quote
Old 09-30-14, 04:05 PM   #825
Fhobbs
Trader Score: (0)
Guess you could run a small bead of a black sealant along the chrome strip and seal. Mine appears to fit tightly at each end but is slightly away from the car door metal through the center portion.
Similar Threads
Thread Thread Starter Forum Replies Last Post
***LS460 | LS460L | LS600hL FAQ (Frequently Asked Questions) DIY/Info Thread*** Tee LS460, LS460L and LS600h 0 08-30-13 08:04 PM
LS 460 TSIBs - Updated 10/17/2007 clambros LS460, LS460L and LS600h 22 02-28-08 04:13 PM
'07 LS460 TSIBs Updated 8/9/07 clambros LS460, LS460L and LS600h 5 08-10-07 06:21 PM
Updated TSIBs - '07 LS460 clambros LS460, LS460L and LS600h 20 07-25-07 04:25 PM
★ LS460 | LS460L | LS600hL FAQ (Frequently Asked Questions) and DIY Thread ★ FAQ & DIY LS460, LS460L and LS600h 0 04-13-01 04:00 AM
Tags
460, caulk, continued, excessive, fix, is350, jthbl46f875008216, lexus, ls, ls460, noise, plastic, problem, problems, trimmer, wind
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
