Ls400 Front Shocks
Super Moderator
The caster bars/strut bars are usually the main cause of the clunking/thumping. Other things are upper and lower ball joints, lower or upper arm bushings, sway bar bushings and/or endlinks, motor mount, rack pinion bushings...
Not familiar with the dynamic handling control...isn'tthis usually integrated with te ABS system? Grand, do you know?
Why did you have a timing belt service performed when the factory interval is 90K miles?
This section is for selling/buying of LS400 items. You'll get a much better viewing by posting similar questions into the main LS400 section.
3UZ-FEEEE
Seems the car has something called Dynamic Handling Control so if it is the front shocks
giving the problem are they standard shocks.
YODAONE
04-13-21 10:07 PM
1LS400Lexus1
12-06-02 10:54 AM
