WTB: 1st gen LH headlight mount
My 1990 LS400 has a cracked LH headlight mount, but the headlight itself is fine.
Anybody out there have a leftover mount to sell me for not too much money?
You can keep the headlamp itself and sell that to someone else for the big bucks.
I'm in the Los Angeles airport area.
Oh, and I could also use the large plastic panel under the engine, but in LA one can easily do without that.
Always screw this up LH the passenger or driver?
What exactly is cracked? If all of your adjustment hardware is fine , I have a 90-94 passenger side mount that would work. It is missing the lower inside mount support , but since it bolts in at 3 other points it makes no difference. Your adjustment hardare should transfer to it.
I removed the old one and found more damage that I thought. I'm going to need the whole LH (drivers) side unit minus the lenses. The left side adjustment pieces are shattered. and the reflector has a tiny hole in it.
