Low fuel can harm the fuel pump
Just thought I would mention this as many people I have spoken to don't know that fuel itself helps cool the fuel pump. I recently helped a good friend replace another fuel pump after it failed within 3 years. He is notorious for running the fuel down to minimum. Although it does not seem like a common failure on our cars I just thought I would mention it for good practices. I always try to fill mine back up around a 1/4 of a tank. I think this is even more important if you live in a warm climate.
Yep, it does indeed.
I'm always getting on my wife about this, but it's a futile cause. It seems like everytime I get in her car, the needle is on empty or the low fuel light comes on.
You can also get in a situation where the only thing left in the tank when it's really low is all the accumulated garbage over the years like varnish and water.
In this era where we have these absurd Ethanol mandates, I see this sort of thing being a bigger issue as the Ethanol attracts water and can make it accumulate in your fuel tank.
Sure it does, it's just common sense how it would go bad if you leave your fuel at the minimum all the time. Dirty particles will sink deep down and when you're low on fuel your engine will start soaking all that in.
Knew lots of cars that had this problem.
Easy rule to follow. Never let the fuel go under the last quarter, that's what I do to remember.
Thanks for the reminder Lav.
thanks for the heads up. I'm guilty of letting the tank get below the empty line as recently as yesterday
in a 15 year old car, i'm sure there is no shortage of mysterious particles at the bottom of the tank. i'll try to be better
in other news, i did get a whopping 504 miles on my last tank which is fantastic
" ethanol in the gasoline attracts water. Initially it mixes with the ethanol, but at higher concentrations it separates and settles to the lowest point, which leads to corrosion and starting and running problems. The lower the fuel level in the tank, the more likely you will experience water contamination."
It makes a difference the concentration that gets sucked up.
Also, a nearly empty gas tank allows more condensation to build up because there's more moist air in the tank.
This is from Honda's website:
I was just inserting additional information because your post seemed to indicate you think it doesn't matter how much fuel is in your tank or whether it's near empty because the water is heavier and will collect at the bottom anyway.
Thanks for your response. I can see how one could interpret my post differently.
I seem to be riding on empty all the time, been that way for years, very bad habit.
Yes the fuel acts as a coolant to keep the pump cool in most cars, but its still safe to run the car to 1/8th or so, that's how its designed, the red light warning system is there for a reason, its time to fill up.
You would be astonished at how far you can drive after the red light comes on, Ive easily gotten 75 kms running on empty, but you are doing a disservice to your car, mainly the fuel pump.
I don't buy into the myth about fuel particles and garbage in the tank, for one our tanks don't rust like they used too, open up a fuel tank from an ls430 and I bet you its clean enough to eat out of.
If there is gunk it would sink to the bottom anyways , and would be sucked up on start ups and just general use, that's what the fuel filters are for.
Its a good idea to keep your tank filled, but don't start panicking if you get low once in a while, especially if the red light hasn't came on yet.
There has been only one instance when I ran out of gas completely so my ls shut off. When superstorm Sandy hit it was a disaster. There was no fuel available for some time so I went to Jersey to find gas. I found what seemed to be the last gas station that actually had gas with a line of cars stretching 4-5 blocks. The last three blocks i had to push my LS - thas was a PITA.
I think you are asking me what car my friend drives? It's an 04 Chevorlet Blazer ZR2. It has 236k on the original engine and transmission. Not too bad considering you usually seems tons of them in the junk yards.
As mentioned, this is not common in our LS's but with other vehicles and cheaper fuel pumps it may well play a roll in premature failures.
