LS430 Cluster Remove- Instrument cluster
Old 04-27-15, 11:07 AM
amals430
amals430's Avatar
Default LS430 Cluster Remove- Instrument cluster
Does anyone know how to take out the cluster from the LS430?
Old 04-27-15, 02:00 PM
KING
KING's Avatar
Please use the search button, this has been asked a million times before.
Old 04-27-15, 02:38 PM
amals430
amals430's Avatar
That is remove the radio not cluster
Old 04-27-15, 04:30 PM
KING
KING's Avatar
Misunderstood, but that's also been discussed.
You'll find 2 small plastic screws on the top part of the cluster. Remove those.
Using a plastic plier remove both plastic parts on the sides(odometer reset trip piece & small dimming **** on the left side with the green and red light.
You should be able to pull the black frame out now, using a plastic plier but being very gentle pull it towards you.
When that's out, you'll find 4 screws holding the cluster in the corners.
GL.
Old 04-27-15, 05:39 PM
xtr3me
xtr3me's Avatar
For visual illustration of instructions provided by theKiNg911, scroll down to pg 71-14 of attached pdf
Old 04-27-15, 08:05 PM
amals430
amals430's Avatar
Thank you so much.
Just don't understand this part and don't know to do it.
"Using a plastic plier remove both plastic parts on the sides(odometer reset trip piece & small dimming **** on the left side with the green and red light."
Old 04-27-15, 09:20 PM
xtr3me
xtr3me's Avatar
Originally Posted by amals430
Thank you so much.
Disregard **** and trip reset button...
Try this.... this how I removed mine
Remove upper and lower steering column cowl.
Refer to link for removal of cowl...
https://www.clublexus.com/forums/ls4...-write-up.html
After cowl removal, loosen two upper cross tip screws on cluster trim ( black ) as shown in pdf. Once loosened grasp screws and pull downward, they are screws within plastic fasteners, same as the ones that hold the plastic trim in the engine bay covering the radiator.
Next slide fingers between the clear plastic of speedo display and cluster trim, at the same time reach through the left side of steering column and grasp the the trim from the side of where dim/brightness **** is located with other hand. Pull towards you with both hands at the same time until clip release. Do right side the same way. My top did not want to release, I used a butter knife wrapped in electrical tape to prevent scratching components and worked it free by sliding knife, starting at one end and working my way to the other until freed. Next disconnect electrical connectors and you'll have access to cluster display
I know my directions may not make any sense, it's been a long time since I had it apart. Let me know if you don;t understand, I can take pics for you, it only takes like 5 minutes. Tomorrow hanging around the house waiting on a.c dude and fishing off the dock, so no problem
Old 04-28-15, 11:02 AM
amals430
amals430's Avatar
I am removing the cluster not anything else.
Just wonder how to remove the left and right reset trip piece & small dimming **** pcs
Old 04-28-15, 11:52 AM
xtr3me
xtr3me's Avatar
The **** can be pulled off by hand. No need to remove as they are snapped into the piece of black trim you are removing, will come out as assembly.. if you desire to remove, grab the piece on each side with fingers and pull ... attached is a pic of how the clips look that retain the piece, they are straight clips
Note the points where clips are located that retains trim in pics below.
I used a butter knife taped with electrical tape when I removed but there is no need, grab upper trim on backside and pull, trim will release easily
Old 04-28-15, 12:48 PM
amals430
amals430's Avatar
Thank you so so so much.
So you are saying, the only 2 screws holding the whole pcs is the upper 2 screws on the back trim.
After remove those 2 screws, I can just pull the whole thing out?
Thanks again
Old 04-28-15, 12:55 PM
KING
KING's Avatar
Nice explanation Xtreme.
Yes Ama, only 2 screws holding the black plastic surrounding part.
I took mine out and painted it very glossy black, now it reflects the dash lights, like a plain! :P
Old 11-27-23, 11:23 AM
cyclehead
cyclehead's Avatar
Default Remove Speedo Bezel
Adding a few more photos showing how to remove the speedometer bezel...
Attached Thumbnails LS430 Cluster Remove- Instrument cluster-img_0152.jpg   LS430 Cluster Remove- Instrument cluster-img_0148.jpg   LS430 Cluster Remove- Instrument cluster-img_0149.jpg
Old 11-29-23, 04:55 AM
TaninAuto
Sponsor
TaninAuto's Avatar
Video overview of the common speedometer and navigation issues. Cluster removal process is towards the end
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Davidc21a
ES - 6th Gen (2013-2018)
09-07-16 05:06 PM
rcan1015
10-25-14 02:26 PM
R1R
05-09-12 11:23 AM
daleer
01-16-05 02:01 PM
Twincharge
11-24-03 04:17 AM
Quick Reply: LS430 Cluster Remove- Instrument cluster
