Rear vip tables
Old 04-24-15, 03:29 PM
Robles84
Robles84's Avatar
Default Rear vip tables
What's up every one. I just picked up some used rear tables out of a jaguar xj8 at pick and pull. 15 bucks for both lol.
Any suggestions on refinishing them due to cracking and mounting them
Old 04-24-15, 05:34 PM
xtr3me
xtr3me's Avatar
Nice find, good price
Is the plastic of the panels cracked or just the clear finish? If it's the finish only, wet sand and spray with clear coat or spray or brush on a polyurethane
As for mounting, remove the back panels from the seats and lay out the table brackets for marking holes, drill marked holes through panels and reinforce backside of panels with metal, plastic, aluminum stock. Preferably something at least the width of a popsicle stick and long enough to cover the 2 holes on table brackets. You can use washers and nuts only if you choose, but a piece of stock would provide better support
Unfortunately ClubLexus blocks persons from uploading pictures when utilizing a vpn. I will have to upload pics of removing seat backs later
Regards
Old 04-24-15, 08:20 PM
Robles84
Robles84's Avatar
The clear lacque coat is cracked From what I see. I don't know how deep it is.
But thanks for the help
Old 04-25-15, 05:52 AM
2KHarrier
2KHarrier's Avatar
This could make for an interesting thread... That's the one option I'm surprised Lexus didn't offer.....
Old 04-25-15, 12:19 PM
xtr3me
xtr3me's Avatar
How to remove LS430 back panels from driver and passenger seats .....
*Tools required - cross tip screwdriver
*Recommended - magnetize screw driver prior to installing screws as they are not easily accessible by hand. To magnetize screw driver, take a magnet and hold driver against magnet at halfway point and pull the driver across the magnet until tip passes completely across magnet. Perform this task 10-15 times and the driver will now be permanently magnetized. To demagnetize reverse procedure. Speaker magnet used in example as shown in picture below
Seat back panel removal -
Steps....
1) Pull outward on left and right side lower plastic trim, then pull cloth away to access cross tip screw
2) Remove left and right side screws ( Note angle of screw driver )
3) Once screws are removed, slide panel downwards if needed as the top of panel is secured by clips as shown in picture below. My panel fell downward on its own once screws were removed
Installation - reverse procedures
Old 04-26-15, 08:55 AM
Robles84
Robles84's Avatar
Wow great write up....thanks for the help. I will post up picks when I get around to doing them. Hard to find time to do things with kids and having them in sports on the weekends lol
Old 04-26-15, 05:13 PM
xtr3me
xtr3me's Avatar
Do post pictures, the addition of the tables is ingenious...
If you're not comfortable refinishing the defective coating, check locally with detailers, auto painters, etc. If you can't find a decent price, ship the defective table to me along with a prepaid return shipping label and I'll attempt to restore it for you at no cost ' of course '
Anxious to see the end result of your project !
Nishy
02-29-16 11:16 AM
frshhhhh
Wheels and Tires Classifieds
02-10-15 06:58 PM
koksik
07-09-11 10:47 PM
Quick Reply: Rear vip tables
