What tire width for my wheels/offsets?
Old 04-22-15, 09:20 AM
jackies
jackies's Avatar
Default What tire width for my wheels/offsets?
Hi everybody!
I'm something of a new LS430 owner - haven't done any mods to show off yet!
My plan was to start with some nice wheels, bought 19"s, 8.5 width for both front and rear.
35 offset in the front and 22 offset in the rear.
My thinking was to get 245/40 R19 tires, I don't want the stretched look.
I also didn't want to stagger the tires so I can rotate them.
But I'm concerned if they will fit without any fender rolling/shaving?
If I drop an inch on lowering springs?
Old 04-23-15, 04:37 AM
ZanderZ32
ZanderZ32's Avatar
Your front will stick out just under half and inch (.4) more than the factory sport wheels.
Your rear will stick out just under a inch (.9) more than factory sport wheels.
This is a great site to compare sizes and offsets (http://www.rimsntires.com/specspro.jsp)
Based on what I have seen here you should be just fine. If you drop the car I would highly consider fender work and or adjustable rear camber arms.
Since your wheels are staggered with different offsets to rotate the tires you will have to dismount and remount the tires. Not as simple as moving the wheels around.
Something to note, I am running a 19x9.5 +35 on all 4 with a 245/40/19 tires as well. Its the widest rim Michelin will warranty that size tire on. If they will warranty it, it is a safe width for a 245/40/19. I did this so I can rotate my Michelin Pilot Super Sports and get some life. I will be adding a small spacer to the rear but over all I am happy.
Old 04-23-15, 06:26 AM
jackies
jackies's Avatar
Thanks for the reply!
This is cool, very close to my prospective specs.
Did you do any suspension or fender mods?
I'm not scared to roll or shave stuff myself, I'm just trying to see if it'd be necessary with 245 tires.
Old 04-24-15, 05:44 AM
ZanderZ32
ZanderZ32's Avatar
Im lowered a little on the factory air bags with the sensor mod. I will get some photos later this weekend. But not fender mods at all.
Old 04-24-15, 08:43 AM
jackies
jackies's Avatar
Sweet!
Some pictures would be great, appreciate your help!
Old 04-29-15, 10:04 PM
ZanderZ32
ZanderZ32's Avatar
Originally Posted by jackies
Sweet!
My cheap Square Setup until I finish school next year.
19x9.5 +35 SVE Drift Wheels
245/40/19 Bridgestone Re760 Sport
Lowered with factory air sensor adjustment
No rubbing anywhere and factory alignment specs
Attached Thumbnails What tire width for my wheels/offsets?-img_7099.jpg   What tire width for my wheels/offsets?-img_7105.jpg   What tire width for my wheels/offsets?-img_7107.jpg   What tire width for my wheels/offsets?-img_7106.jpg   What tire width for my wheels/offsets?-img_7109.jpg
Old 04-30-15, 05:43 PM
jackies
jackies's Avatar
Thanks for the pictures.
It looks like you have plenty of space, so I probably won't need any fender mods after all.
Well, the time will tell.
Old 04-30-15, 09:08 PM
ZanderZ32
ZanderZ32's Avatar
Yeah I think you will be fine. I may add a spacer to the rear on my setup shortly. Best of luck on your setup, be sure to post it up when your done.
A3OD
09-12-21 07:33 AM
Silver460L
10-28-14 07:27 AM
ilv1004s
05-20-14 08:17 PM
IS3FIDY
04-28-14 03:38 PM
KOMPLEX
06-08-06 05:57 AM
Quick Reply: What tire width for my wheels/offsets?
