Frequency of soft close door lock actuator failure?
Old 02-26-15, 03:21 PM
ma61
ma61's Avatar
Default Frequency of soft close door lock actuator failure?
Was browsing the repair history of an 04 LS430 I found for sale and came across this:
So that makes me wonder:
a) Is this the right price!?
b) Do these commonly fail, or is this a rare occasion?
Did some investigating and the actuator list price appears to be $659, and book time is an hour labor. I'm wondering how this particular Lexus dealer ended up with this price.
From what I can tell on the standard LS without the soft close doors, the actuator is part of the lock assembly and comes in at $133. So as assumed it is less than the fancy motorized actuator.
Anyone have experience with this?
Old 02-27-15, 07:46 AM
BradTank
BradTank's Avatar
It almost looks like the repair was both to replace the soft close actuator and the power door lock? So two repairs and two parts total. That's just a guess, but it's definitely an eye popping number.
I see things like this and I'm glad I got a stripped down, regular LS
Old 02-27-15, 10:22 AM
Dr. Jekyll
Dr. Jekyll's Avatar
Yes that's the right price as it's the soft close function that's very costly. The replacement actuator for the door is only $6 and the latch portion which recently failed on mine is $200.
Old 02-27-15, 10:23 AM
Dr. Jekyll
Dr. Jekyll's Avatar
Oh and I have a 2004 LS with 53k miles and have never had a soft close fail, just the $200 latch which was replaced by my mechanic with an hour in labor.
Old 02-27-15, 10:46 AM
Lavrishevo
Lavrishevo's Avatar
Easy Close is the term Lexus uses I believe. I have no issue with mine. 2004 with 127k. They are not a common failure.
Old 02-27-15, 11:07 AM
ma61
ma61's Avatar
From what the one line of description says from the repair order, it looks as if the actuator and "easy close" mechanism are all one assembly.
SO, if the actuator fails and you are unable to lock or unlock the door, that means you have to replace the entire actuator/easy close assembly rather than just an actuator?
Old 02-27-15, 11:10 AM
Lavrishevo
Lavrishevo's Avatar
You can replace the door lock actuator without replacing the easy close mechanism. I have done this on my drivers door. The motor is the standard d-shaft that is used in all the 430's.
Old 02-27-15, 11:57 AM
sakoa
sakoa's Avatar
Same here, 2004 with 128k and I've never had an issue with any of mine. As BradTank suggested, it was probably just the actuator and the dealer wanted to replace the entire door lock assembly.
Old 02-27-15, 02:19 PM
BCrews
BCrews's Avatar
Considering how many people in the 430 forum HAVE talked about this issue and I've never known anyone to replace a door lock on their auto lock cars, I'd almost call this a defect. My auto door closer works- but the passenger lock will not lock/unlock on it's own and needs to be adjusted from inside the car.
Ironzey
05-29-17 02:11 PM
69charger
12-03-12 06:45 AM
Gunnut
07-17-10 09:26 AM
MasterG
Maintenance
04-16-03 09:20 PM
Quick Reply: Frequency of soft close door lock actuator failure?
