06 LS430 mirror puddle lights not functioning?
Old 02-10-15, 05:44 AM
LiCelsior
Retired
LiCelsior's Avatar
Default 06 LS430 mirror puddle lights not functioning?
Got a weird problem on my hands, i had originally swapped out the incandescent bulbs that were in there for some LED bulbs and they worked fine for months. Now i went to swap them for even brighter LEDs and first one side stopped working, then the other side . I swapped them back for the regular bulbs and same deal. I checked the fuses related to the mirror lights and they are still good. Has anyone else experienced this before? If so then what was your solution?
Old 02-10-15, 06:09 AM
Lavrishevo
Lavrishevo's Avatar
Do you have a multimeter that you can check for 12V DC at the bulb connector itself? I would start there. Trace the power.
Old 02-10-15, 09:33 AM
LiCelsior
Retired
LiCelsior's Avatar
Yea i'm going to have to try that when i get home.
Old 02-11-15, 12:31 AM
AYEmike
AYEmike's Avatar
Did you poke the prongs that keep the bulbs in place with some kind of metal when trying to replace them? Could be the cause, it would cause your fuse to blow or the bulb connector to go bad.
Old 02-11-15, 07:44 AM
LiCelsior
Retired
LiCelsior's Avatar
nope, only pulled out the bulb and then it stopped working.
Old 02-11-15, 07:51 AM
Jdmdrew
Jdmdrew's Avatar
You may have had some bad luck sticking the plug in because LEDs need to plugged in the correct way. I notice when I stick them in one way, it will not work, then it works when i flipped it around. Also, you may need to play with the prongs a bit an straighten them up. They are tiny prongs so they are manipulated easily when installing and can fall out of place. Im not sure what the odds are of it being the wrong way the 4 times you tried but I am hoping that will be the fix.
Old 02-11-15, 07:55 AM
LiCelsior
Retired
LiCelsior's Avatar
yea i thought that also, so i flipped the bulb and it didnt work. put in the regular yellow bulb and it didnt work also.
Freds430
ES - 6th Gen (2013-2018)
04-19-16 11:01 AM
Spamboi
09-17-14 02:18 PM
GoGators
GX - 1st Gen (2004-2009)
11-02-13 11:20 AM
Tiggerr
RX - 3rd Gen (2010-2015)
81
01-02-11 08:35 AM
MAV3556
IS F (2008-2014)
08-19-09 03:43 PM
Quick Reply: 06 LS430 mirror puddle lights not functioning?
