2004 - abs, trac off, check vcs, tpms check system
When i go above 85 mph i get the ABS and TRAC OFF lights and , CHECK VCS and (TPMS) CHECK SYSTEM on the display. they all go away after i come to a stop and start moving again. any ideas what it could be? i just had my breaks done also.
Please check to see if you can pull any Diagnostic Trouble Codes (DTC) from your car's memory. If so, look them up against the attached chart to narrow the cause of the problem.
i dont have a scanner to pull codes. do you think an place like autozone could pull these codes for free?
Did a Lexus dealer do ur brakes?
