Lsd for ls430
Old 12-07-14, 06:02 PM
sr20dets13
sr20dets13's Avatar
Default Lsd for ls430
So my ls3 swapped 430 can't even slide :-/ stupid open diff! So I've done done searching and I know toms and I think cusco does. Anyone know for sure any oem ones that I could bolt up? I read something about the supra. Or anyone have any hookups to just get a toms.
Old 12-07-14, 08:44 PM
sr20dets13
sr20dets13's Avatar
Mods can delete
Old 12-07-14, 08:47 PM
LiCelsior
Retired
LiCelsior's Avatar
did you find your solution?
cusco and toms are just ridiculously expensive..might be cheaper to pull a supra diff and see if itll fit inside the housing of the LS diff lol.
Old 12-07-14, 11:03 PM
JoshuaaXD
JoshuaaXD's Avatar
I've tried to slide my ls430 and it's open diff af! Come down to stockton, we can compare your diff to a kazz lsd we have for an mk4 supra. You can tandem with our 6.0 vortec powered fc too haha we have a skidpad at the shop.
Dandan573 (02-05-24)
Old 12-08-14, 08:35 AM
sr20dets13
sr20dets13's Avatar
I'm going to check out some supra diffs, but if I can't make a match Im forking out for the cusco hybrid. Kinda cool you can switch from 1way to 2way.
Old 12-08-14, 08:38 AM
sr20dets13
sr20dets13's Avatar
I Been asking around and don't think it's going to fit in the pumpkin, maybe. Was gonna see if we could find a whole diff that can bolt up or come close. Otherwise **** it 1600 for cusco get it done.
Old 12-09-14, 11:54 AM
sr20dets13
sr20dets13's Avatar
is there anyone that can comfirm that the mk4 auto supra differential is same as ls430? i went to buy the cusco unit and its 8-10 week wait.. but i did find a unit on the shelf for a auto 2jz mk4 supra. but would hate to spend 1700 and it not be swappable. so if theres anyone that is 100% sure please chime in.
Old 12-09-14, 02:34 PM
sr20dets13
sr20dets13's Avatar
so heres what i did, i looked up the code on the for the cusco unit. found a Japanese catalog the same model diff bolts into a soarer uzz40, aristo jzs160 161, celsior ucf30. so then i ebayed jzs160 lsd came up with tomei, kaaz, os giken all fitting supra jza80. but if current lsd is a torsen open diff half shafts will need to be purchased. so tomei being the cheapest i called tomei, tomei said that if my ls430 is open diff then diff 562027 will fit right in with no half shafts. and thats the diff that i had came down to so just ordered it.. 1000 bucks i hope it fits. or ima be flipping a new aristo diff real fast.
so if you can find a soarer jza80 at should bolt into the pumpkin but i think will need the torsen half shafts. same goes for aristo jzs160-161 lsd. ill be chiming back in if im wrong with all this.
Old 12-09-14, 09:47 PM
LiCelsior
Retired
LiCelsior's Avatar
nice research man, hope to hear how it works out.
Old 06-01-15, 10:12 PM
mk4umha
mk4umha's Avatar
How did the Swap go?
Old 08-01-15, 01:17 AM
sr20dets13
sr20dets13's Avatar
Did not work man.. So basically the aristo uses a half shaft where the ls430 is a full axle with the splines going straight into the pumpkin. So I welded it and honestly I'm ok with it.. I still want to find a LSD diff. Good news is I bought a aristo today lol, so I have a diff for it :-) I'll get back if I find something for the ls430
Old 08-01-15, 11:22 AM
VanCityLS4
VanCityLS4's Avatar
A few months ago there was a done out drift style LS430 on Seattle Craigslist. Probably worth every dollar of that 20 something thousand. He was running a ATS brand 2 way LSD.
Old 01-20-16, 04:50 PM
seve7
seve7's Avatar
i have called ats.... they need to special order it from japan, but its about 1350$ i think was the price. i really like how adjustable it is.
Old 01-20-16, 09:19 PM
Arcturus
Arcturus's Avatar
Someone selling LSD?
Old 01-23-16, 06:58 AM
tradosauru
tradosauru's Avatar
I'm wondering how much the OP is spending on the ability of this luxury automobile to slide?
I thought I heard it all but evidently not.
Quick Reply: Lsd for ls430
