Staggering conservatively...Help!
Old 10-15-14, 01:03 PM
KingLS
KingLS's Avatar
Default Staggering conservatively...Help!
I just picked up a gem '03 ls430 with 24K miles... I've finally decided on a set of wheels. 20"x8.5 fronts with 10" rears. I plan on adding the Tanabe NF Springs to lower it an inch. My goal is a clean, agressive look that's kinda flush. The tire size that's recommended is 245/35 in front and 275/30 in back. The offsets that are available for the wheels are 30/35/40 for the front and 35/40/43 for rear. Hoping to get some help from you LS owners with experience, considering I'll be ordering this online and want it to be right the first time... (not thrilled on the idea of rolling or shaving)
Old 10-15-14, 01:14 PM
j stuff
j stuff's Avatar
I have tanabe DF210 springs fs! I dont think youll have any problem with any of those offsets to be honest with that drop.
Old 10-15-14, 06:15 PM
KingLS
KingLS's Avatar
Thanks for the response, but I know those offsets I provided are within range for our cars... but having the choice when I order them, which should I choose? And, do the tire sizes seem appropriate that I mentioned above?
Old 10-15-14, 10:16 PM
j stuff
j stuff's Avatar
i think the tire size sounds good. a lot of people are running that. As far as offset, I would go with 30 in the front and 35 in the rear.
Since the fronts are 8.5 you're gonna want the lowest offset you can go as 8.5 is kindaaa sorta narrow. Most people go for 9 up front. rear I would go 35. Also for resale in the future they are more attractive options for others to buy
Old 10-18-14, 05:12 PM
ancdmd
ancdmd's Avatar
I had the same setup with either 35mm or 38mm (can't remember but I'm pretty sure it's 38) offset in front and 37mm offset in back. I wouldn't go with 30 in the rear, you will rub the fender. With the 275 on my rear 37mm offset, the tire was really close to the fender. I've changed my tires to 255/35 in front and 285/30 in back since I'm not a fan of the stretched look, and I've shaved the rear fender lip,which is something I've regretted. I love the bigger tires, just wish the offset was different on my rears. The 275 will be a little stretched on that rear 10" wheel.
Old 10-20-14, 04:42 PM
ancdmd
ancdmd's Avatar
Here's mine
Old 10-20-14, 04:43 PM
ancdmd
ancdmd's Avatar
Rear view again
Old 10-20-14, 04:44 PM
ancdmd
ancdmd's Avatar
Front view
Old 10-20-14, 04:45 PM
ancdmd
ancdmd's Avatar
Another front
Old 10-20-14, 08:44 PM
ancdmd
ancdmd's Avatar
In case anyone is curious and as a follow up to the above pics, I've done a little measuring of my wheels, best I could with a tape measure with them on the car. It appears my offsets are as I remember I had ordered them, 40mm (not 37mm) for the rear and 38mm for the front. Tires are Michelin Pilot Sport A/S 3, 255/35 in front and 285/30 in rear.
Even though the wheels are spec'd at 8.5" in front and 10" in back, they actually measure wider to the outer lip. Best I could estimate is that they are about 9.5" and 11" respectively. I measured the distance from the outer lip to the hub mating surface to do my computations.
I also have the shorter camber rods installed in the rear to upright the tire and give it less negative camber, saving the tire from premature inner tread wear. Without these rods I'm sure I could have saved myself from having to do at least some of the shaving/rolling that was necessary to fit these tires.
Old 10-21-14, 07:46 PM
ancdmd
ancdmd's Avatar
I am guessing that's plenty of clearance from the air shock...
Old 10-27-14, 07:06 PM
KingLS
KingLS's Avatar
Thanks again, a lot of good info there... I went to order the package at element wheels, and they put me back on the fence about the wider tires (285/30 rears and 255/35 fronts). The service rep was the "lexus specialist" supposedly, and said there have been complaints of rubbing with that combo. Also taking in consideration the 1" drop from the springs. AAAARGH!!! This has become way too difficult.... can anyone out there vouch for that tire set-up with Tanabe NF springs, or do I need to just settle for the 275/30 & 245/35 combo?
Old 10-27-14, 08:28 PM
ancdmd
ancdmd's Avatar
Did he say where the rubbing occurs?
Old 10-28-14, 09:04 AM
KingLS
KingLS's Avatar
Nooo (hanging my head).... I'm just a little hesitant because your car has air suspension, and mine will be on lowering springs, and a little difference could potentially cause more rubbing. Do those pics u posted have the wider tires or the originals?
Old 10-29-14, 07:48 PM
ancdmd
ancdmd's Avatar
The pics I posted in this thread have the wide tires. It shouldn't make a difference whether you have air or springs, unless the spring assembly is wider than the air shock, which could then cause an interference problem on the inside. I'm surprised nobody else has any input here with experience with their own car. Were you settled on the 40mm front wheel offset and 43 for the rear? You certainly won't rub the outside of the front with a 40mm offset, and I'm fairly certain you'll be ok in the back also, especially with the stock camber bars. Maybe he's talking about it rubbing on the inside?
Quick Reply: Staggering conservatively...Help!
