fitment gurus
fitment gurus
Hey guys I just need a little help getting pointed in the right directions.. I have an 06 and on air. I don't want to waste money and try my best to get this right the first time. Wheels are my next purchase and I need help tucking my wheels. I would like to tuck my wheels in when I hard park and from the research I've been doing this is what I came up with:
20x9 +26
20x10 +32
I'm not sure what size tires to run yet but what do yall think? I will be shaving my fenders and If needed I don't mind doing a pull in the real. Any input would be greatly appreciated.. because I am in need of some wheels in my life.
20x9 +26
20x10 +32
you should be okay with tucking those. What air on you on? Factory air doesn't go as low, so you might be able to tuck slightly on factory air because you're not gonna get a lot of natural camber as you would with aftermarket air. i would run 245/35 rears and 235/30 fronts. you probably do not have to pull the rears, just a shave. i am running 10.5 +15 245/35 and 10 +18 235/30, and i slightly tuck the rears with -8 camber at ride height with a small pull and camber arms. but you can tuck those perfect, no problem. My buddy is running -2 camber and tucking a little on 10.5 +30, and yours is about .5" weaker. hope this helps.
xxwhosnxt
Suspension and Brakes
16
02-23-16 03:01 PM
tesito1
08-09-10 10:09 PM
e60
GS - 1st Gen (1993-1997)
11-10-09 09:16 AM
