Back up camera or control module?
Old 10-09-14, 06:07 PM
Slvr surfr
Slvr surfr's Avatar
Default Back up camera or control module?
I've been having a blank/ grainy blackish screen when in reverse some time now. Has any one else had this issue and if so, did you get just the camera replaced, control unit, or both? How can you tell if its one and not the other?
Old 10-09-14, 07:14 PM
rkw77080
rkw77080's Avatar
Does the screen work properly when the shifter is NOT in the "R" position?
If so, please take a look at the following fuses in the luggage (trunk) J/B:
1. RR ECU-B
2. RR ACC
3. RR IG
Old 10-10-14, 12:32 PM
Slvr surfr
Slvr surfr's Avatar
1. RR ECU-B
2. RR ACC
3. RR IG
Yes everything else work as advertised. I will check out those fuses and report back.
Lexpilot53
RX - 1st Gen (1999-2003)
06-07-16 03:23 PM
akhong
02-12-10 08:24 PM
robinzon
GX - 1st Gen (2004-2009)
27
11-21-06 09:26 PM
mrjohal
SC- 1st Gen (1992-2000)
12-09-05 09:40 PM
Quick Reply: Back up camera or control module?
