Recirc/fresh not changing over.
Old 09-28-14, 01:39 PM
MileHigh
MileHigh's Avatar
Default Recirc/fresh not changing over.
Hi all. On my "New" 2004 LS430, I have discovered that the door/flap (I assume that's what it is) in the HVAC that changes position when you select Fresh or Recirculating, is apparently not moving. It stays on Recirc all the time. So there is no fresh/cool air coming in. All other controls appear to be working as they should. The button shows the lights as if it's okay. Is it likely to be just stuck, and needing to be freed up, or is it more likely to be "had it" and the door and/or motor need replacing? Any thoughts?
I have since been doing a bit of checking. I've had the radio etc out, but there didn't look as if there was anything behind there. I also removed the lower panel beneath the fan unit, but couldn't specifically see anything. Then I had a thought, wonder if the door is electrically driven, and maybe I might be able to hear something, even if it was just a click. Turned on the ignition, and pushed the recirc/fresh button. Yes, there was a motor sound, could be heard going in both directions. That was down beside the fan unit, but couldn't actually see anything. So I'm wondering if maybe a rod, or cable, has come detached from the door or actuator, assuming that was the correct actuator motor I could hear. So, how do I get at it?
Oh, and it's a right hand drive car imported into New Zealand from Singapore. Would the Transmission TSB apply to this car? I assume it would, in which case, how might I found out if it's been done? Cheers, Keith
Old 09-29-14, 06:55 PM
rkw77080
rkw77080's Avatar
There are 2 "Air mix" servomotors, 2 "Air outlet" servomotors, 1 "Cold air bypass" servomotor, and 1 "Air inlet" servomotors. Diagram below shows their relative positions for a US model. Please let me know if you have questions.
Old 10-02-14, 05:15 PM
MileHigh
MileHigh's Avatar
I thank you for that RKW. Looks as if it'll be a real mission getting into anything there! But I'll have another look.
lanesm
RX - 3rd Gen (2010-2015)
02-14-17 09:07 AM
steerpike
07-05-16 12:26 AM
snakehead
05-05-16 04:50 PM
gtbreeze
07-28-11 09:46 AM
johnna
11-24-05 07:56 AM
Quick Reply: Recirc/fresh not changing over.
